AFM actuators have failed again on track for my Z51
#181
Sigh. My 2017 GS is at the dealer again, because 3/3 track events I get a P12F0 code and a nasty banging sound. I told the service guy I suspected a heat related issue. It seems to happen towards the end of a day, after the car has had its cool down lap, and if it is turned on again within 30 minutes of tracking it. The code is not thrown on the track -- it is thrown upon starting after a series of track sessions.
It is has happened to me at CoTA in 90F temps, and MSR at 60F temps.
(I'm not satisfied my dealer has quality vette mechanics. My car has been in the shop for this issue for at total of 5 weeks and it just went in again yesterday -- I'm thinking of asking them to pay a month of ownership to me (joking)).
I'm happy to find it is not just me, but I'm quite unhappy that it is a problem at all, a recurring one at that.
I ended up pulling fuse 32 to disable the actuators, so no more banging. And, to me, I can't tell a difference in exhaust sound. I check the codes occasionally to make sure nothing new has popped up since the CEL is always on. I also went to the track again with fuse 32 pulled and had zero problems.
What I'd really like to know is if you pull 32 before going on the track so that the actuators don't move while they're too hot and then put the fuse back after the car cools off, will that help prevent the actuators from being damaged. I'm going to try this out if I can get the dealer to replace the actuators.
#182
Pretty sure the actuators will fry whether the fuse is in or out. Maybe install cutouts upstream of the actuators and go open exhaust out the sides.
#183
Sr.Random input generator
I probably have said it too many times, but it feels appropriate to remind again: leaving the actuators (with their butterflies) dangling next to the exhaust works. I've done countless track days in various conditions, and never had a problem:
How-To: Eliminate AFM actuator melting issue for aggressive/track driving
#184
And it came back from MSR with the problem, so it is back at the dealer.
@X25, I read your post on how to eliminate this, but it requires voiding my warranty. I have 6k miles on the car; I'm not ready to start cutting. Unfortunately, I have to consider this a non-solution. But perhaps my tolerance of track-dealer-track-dealer will persuade me to listen to reason.
I am disappointed that this track beast of a car (2:37 @ CoTA, 2:37 @ MSR 3.1) continues to break. Paddles are great for the track, I have zero issues with my A8 temps (I use manual mode exclusively, and select my own shift points). So why AFM is deleted from M7 because it is more "track-oriented" is a mystery to me.
#185
Why don't you try the solution BaylorCorvette did? This doesn't sound like something that would void the warranty and it works.
"A GM engineer at one of the IMSA races last year told me the '16's had the "upgraded part" in them. If true, I ruined one at a track event last year. So what I did is unbolt the AFM actuators, and put several washers in between them and the flange they mount to to act as a spacer/heat sink. It also requires longer bolts but I just got those at Home Depot. So far the mod has worked, and I've put a few hundred track miles on the car since I did this. Of course the AFM actuators no longer function correctly but not a problem for me since I never use Eco mode in my M7. "
#186
Well, I'm learning things. I thought that the GS didn't have the AFM actuators installed. I was going to look at a GS tomorrow, but now I think I'll just keep my car.
#187
#188
Ok so I have a '14 Stingray now... has anyone made a module to plug into them to fool the computer? I don't want to hack the exhaust.
#190
No they don't anymore. I was told that HP Tuners now allows the error codes that happen when you remove the AFM actuators to be tuned out via the FSCM module.
#192
#193
Fair point.. same reason why I haven't tuned mine as yet. If I break my AFM valves I will do the fix that BaylorCorvette did.
#194
I'm Batman..
Pro Mechanic
I was told this as well. Though I can't seem to figure out how to do it in HPT. The AFM codes are B-level and the FSCM appears to only show C level and higher codes for me. I'm sure i'm just doing it wrong..
#195
Does anyone have the contact to the GM rep here on the forum? My AFM valves failed at the track and the shop here doesn’t want to swap them under warranty because I went to the track and they failed there from the trans overheating
#196
Maybe if you reach out to EFI Tuning on their Facebook page, he can help you. Just a thought..
#197
I'm Batman..
Pro Mechanic
Yea I have the contact info for the guy at EFI that knows all this stuff.. I just don't want to bother him too much lol. I'm going to take the car out tonight or tomorrow with the valves disconnected (fuse #32 pulled) and let it generate the codes and then go in and see if I can get them to disable in HPT. If not, then I may reach out after trying and failing.
daleong (12-14-2017)
#198
Let me know if you figure it out.. i'd like to get mines tuned out at some point also.
#199
I'm Batman..
Pro Mechanic
Pretty sure I figured it out. Will need a couple days to drive around and confirm. Its important to note that it require tuning the FSCM (C304 on the controller list) which is a seperate computer from the ECM. As a result it requires 2 extra HPT credits to tune that computer.
daleong (12-15-2017)
#200
I'm Batman..
Pro Mechanic
I figured out how to actually tune the AFM valves out. Thanks to TSloper for his help with this. Check out my guide:
https://www.corvetteforum.com/forums...hp-tuners.html
Ant
Ant
daleong (12-24-2017)
