Added a Catch Can today on a Non-Z51
So I noticed a thin coat of oil on the back side of the TB blade and hope this catch can helps from ingesting in to the intake after the TB. I never added one on any corvettes or others I have owned in the past and never seen a need for one.
I'm Batman..
Pro Mechanic
Check out my thread on it. Its definitely necessary!
https://www.corvetteforum.com/forums...-this-out.html
Ant
Ant
Supporting Vendor
The ZO6 I have heard has a very good PVC system to stop oil getting into the intake.
So Bob how many miles, how many miles for that amount of oil, is it a Z51, how long have you had the can on, year and how did you do the brake-in? I saw no sign of oil except a very fine film on the back side of the TB blade on mine.
I was thinking that also but for a different reason ( the fumes being cooler entering the intake). It is not mounted to the block but it does absorb / soak the heat.
Ant
Ant
I installed the can in Oct after reading about oil ingestion and cars pushing oil into the air intake system, but my car never did any of that.
I did remove the TB and found oil behind it, before the can install, this could have been from the original oil and it being overfilled.
The oil was barely a bottom cover of oil in the catch can, I did not measure it, possibly a tablespoon full.
I'm sure this thing pulled out oil vapor and condensed it in the can which is it's job, I have seen the same amount of oil behind my 5.3 chevy truck.
Supporting Vendor
It is just physics. You can get the oil out of the air by cooling or slowing it down. Longer hoses, baffles and a cool CC is how the oil and water is removed.
Received 19,289 Likes
'20-'21-'22-'23-'24
Nice addition to the car. I've got one on my C5 and it gathers up a noticeable amount of oil in a few thousand miles.
