Will you be spraying 100% meth? if so, you MAY be able to get to 800, but it seems risky on the stock bottom end. Im keeping a stock bottom end and going for about 700 RWHP, and I will be spraying 100% meth.
Yah with meth but was gonna keep it at 700 and get the z06 fuel pumps and injectors and and then add the E85 and go for the 800 to 800+
So will it be safe to have 800+ wit forged Pistons injects and higher fuel pumps
I personally didn't feel like going higher than 700hp without getting pistons. Injectors and pump is just another way to get more fueling into the mix. Gives much more over head.
