Source for 180 Thermostat?
Old Jan 17, 2016 | 11:53 AM
Flame Red's Avatar
Flame Red
Default Source for 180 Thermostat?
I was going to swap out to a Dewitts Radiator this week and I thought while I had the system open I would install a 180 stat. Found some threads but it looks like the Lingenfelter and others are all out of stock everywhere I checked.
From prior generations, I know 180 is best for me.
Anyone know of a source for a 180 stat in stock?
Please, do not turn this into a stat debate. Just looking for source.
Old Jan 17, 2016 | 12:39 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
i would call lingenfelter looking for when they will have the updated stat ready.
Old Jan 17, 2016 | 02:26 PM
dovervold's Avatar
dovervold
All kinds of people having problems with the Lingenfelter stat. Check some threads. Seems like LMR has a new housing and stat that people are leaning towards, that is where I am headed. Good luck...
Old Jan 17, 2016 | 03:02 PM
6Speeder's Avatar
6Speeder
The bulb in the Lingenfelter stat is good, it's the gasket that is failing. I took apart the Lingenfelter stat and put it's bulb in the shell/gasket of a stock GM stat. Works like a charm and isn't prohibitively expensive, like some who sell housing and stat.
Old Jan 17, 2016 | 08:16 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
This is available at SUMMIT Racing for under $30.00
CHEVROLET CORVETTE JET Powertech Thermostats 10167
Thermostat, Powertech, 180 degree,
Application - Thermostat Fitment:
Make: CHEVROLET
Model: CORVETTE
Submodel: STINGRAY Beginning Year: 2014
Chevy small block Gen V
Make: CHEVROLET
Model: CORVETTE
Submodel: Z51
Engine Size: 6.2L/376
Old Jan 17, 2016 | 08:43 PM
dovervold's Avatar
dovervold
Speeder, that is good to know. Would rather not spend the coin for housing and just retro the LME stat...
Old Jan 17, 2016 | 09:41 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Make: CHEVROLET
Model: CORVETTE
Make: CHEVROLET
Model: CORVETTE
Submodel: Z51
this^^^
We both have these installed and they are MUCH better than the Lingenfelter. The seal is much thicker and molded onto the TStat. Pretty sure they offer 160, 170, & 180 tstats.
Old Jan 17, 2016 | 11:54 PM
EcoBrick Bob
Summit markets the 160 & 170 as their own brand, while the 180 is branded as a Powertech. From their pix, they look identical though. My experience with the Summit 170 is that the seal cannot be removed and thus shouldn't fail. In normal highway driving, I see 172-178 deg temps. If I sit at idle for a few minutes the temp goes up to nearly 200, but still less than the stock Tstat readings. I have no tune, so my fan temp settings are stock.
Note that from the pictures, the ones available from Summit look identical to the Lingenfelder ones, and different than the stock Tstat. Both of the 160 & 170 that I got from Lingenfelder had seals that failed because they could easily come off the rim of the Tstat. After waiting a couple months for revised ones, they refunded my money. They were very easy to deal with... Great Company.
Old Jan 18, 2016 | 02:43 AM
Seannyc's Avatar
Seannyc
I also have the 170 T Stat from Summit it's great only problem the temp gauge does not show real temp u have to put it in touring theme and go to performance and see the engine temps
I get on the highway on. Steady pace
170-178
street 175-185
Stand still 190-197 barley tho
Old Jan 18, 2016 | 08:39 AM
StingerBG's Avatar
StingerBG
Are you still on the stock radiator also?
Old Jan 18, 2016 | 09:19 AM
MIGHTYM0USE
i made a thread on this, they are all the same. buyer beware. - but as i posted you can salvage the bulb into the stock housing and it works like a charm.
Old Jan 18, 2016 | 09:54 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Are you saying the Summit ones are the same as the Lingenfelters?? If so that is most certainly not true. Maybe the bulb itself is the same but the gasket setup is completely different..
Old Jan 18, 2016 | 01:30 PM
MIGHTYM0USE
show me a picture comparing the two, everything available on google is the same stat (besides oem)
https://www.corvetteforum.com/forums...is-repair.html
Old Jan 18, 2016 | 05:42 PM
Newton06's Avatar
Newton06
Yup. Not worth the pain & aggravation this caused me when the gasket failed.
Old Jan 18, 2016 | 06:22 PM
Flame Red's Avatar
Flame Red
ARGH! After reading Mighty Mouse's thread, I think this is a bad idea and I'll just send the 180 stat back to Summit and just install the Dewittes radiator and leave the stock stat alone.
Old Jan 18, 2016 | 07:01 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I'll post pictures when I get home later. I've owned both, the same as EcoBrick Bob has. The summit one is different and better.
Old Jan 18, 2016 | 07:37 PM
Seannyc's Avatar
Seannyc
Get the 170 thermo it's a deferant brand and new gaskets up to u tho
To Source for 180 Thermostat?
Old Jan 19, 2016 | 02:04 PM
MIGHTYM0USE
you think this is different? you have pics of yours?
Old Jan 19, 2016 | 02:22 PM
Seannyc's Avatar
Seannyc
Yes I think the 180 is a deferant brand and
170 is summit brand and I have it works fine had it about 3 months
Old Jan 19, 2016 | 02:23 PM
Seannyc's Avatar
Seannyc
Sorry no pics but the runner is stuck on wont come off
