Installed a Magnuson Supercharger on a Z51...
That's much appreciated! I'm a few months out on a decision, the biggest hurdle for me on the Magnuson is the lack of CARB cert. I think I read it's pending, but I haven't reached out to them to see what that means.
I'll definitely take you up on that offer though if I do go that route, thanks!
The power is delivered higher in the RPM range with centris so yes it has an upper RPM hook that you will feel and is measurable on both dyno and mph on time slip.
That's bc they don't compare compressors to one another correctly.. Take a novi 2200 or vortech YSI vs a 2300... Sure it will have more topend from the centri due to the cfm the blower can move... BUT that's only when you start pushing them into the 850+rwhp range where the 2.3 is not capable of pushing enough CFM
To the OP; Very nice setup and install.
The new Magnuson shows they put time into R & D.
[QUOTE=sagertat;1591395015]Spent a few days to install a Magnuson supercharger. Great kit. Amazing instant power.
Wondering how many others have this kit installed?
Happy to answer questions for those thinking about it.
Thanks for your story. I'm having one installed as soon as the snow melts up here in Ontario Two questions for you - one good and one dumb:
1. Any significant reason that you went with the stock pulley other than ease of installation? I'm told the smaller pulley will produce about 9 psi of boost versus 6 with the stock pulley and will also add about 40-50 rwhp. Not bad for a part that costs only $149!
2. Here's the dumb question: does the Magnuson/Heartbeat name appear anywhere on the top of the unit? From your picture it doesn't show anywhere??
Again, thanks for your story!
The PD will get the jump if it gets traction but that will not be the case with street tires in most cases.
Both have their attributes, choice depends on use and preference.
[QUOTE=LuckyGuy;1591398653]
I wanted a more conservative power increase to offset altitude losses as I live at 5000 ft elevation. No doubt that changing the pulley will increase the boost but you're also putting more stress is on the single belt design and the LT1 stock engine. I already have trouble putting down the power
it added. But it was definitely worth the 6 psi I'm set up for.
As for the badging, they do include a plastic trim piece that goes around the supercharger. It's just not installed in the picture. They also include some window stickers.
LuckyGuy (01-26-2016)
Good job! I too have the Magnuson and did long tube headers as well. Love the power but will be looking at bigger tires and wheels soon. I did not do mine myself and had a pro do the tuning. On the dyno it was reading 548 hp and that's with the tires smoking from the loss of traction on a cool night. I had mine installed 3 months ago and still trying to get used to the awesome power-I'm a little cautious and trying to keep it in my lane! Enjoy!
2700 miles. There was some minor coking on the valves and some oil film in the plastic manifold I removed. I think oil in the intake is real and coking on the valves is real. But it can be reduced by keeping the oil down on the dip stick. Whether or not it will cause issues or is just cosmetic as Tadge implies remains to be seen. I'm not going to lose sleep over it. And I'm not going to add a catch can. I'm not keen on the Z06 catch can solution where they are plugging the hole in the supercharger.
Received 1,694 Likes
St. Jude Donor '15
I emailed Magnuson to ask about the CARB cert. I dunno, I invited them to the thread, they are forum vendors. Maybe they'll chime in.
I was talking to Magnuson last week and they said that they have all of the paperwork in and are anticipating no issues at all with their CARB certification - it is just a matter of bureaucratic inertia at this point!
Rooster OG (01-26-2016)
Yes the centri will be charging forward at a higher speed and catching up, it's inherent of their design to have a stronger top end charge. I'd suggest looking at Forced Induction section for C6 here on CF for a large database of opinions, experiences and actual numbers as same will hold true for C7 aplications.
#33
Very nice. Keeping the stock pulley was a good call. You can get used to this jump in power, and down the road gives you another easy mod to get some more out of it. Also, the stock tune from Magnason only covers stock configurations, so a custom tune is needed.
I'm sure the CARB cert will be coming soon. They are California based, and don't know if any prior blowers of theirs that didn't get the cert.
#34
#35
Agreed, but since he installed the stock tune from Magnason, he wasn't planning on doing custom tuning right away, if ever(most likely will.....the mod-bug bites HARD)
I've been through my share of tooners with my supercharged G8.
#36
St. Jude Donor '15
Ok, so when the state gets around to it, it should be approved by the time the c8 rolls out. Perfect!
#37
#39
I no a few guys with a z06 never felt it tho but since the centi makes more power up top that's where I like the power highway pulls roll racing
#40
Centri seems to make more power at the top because it isn't capable of making boost at lower RPM - boost is a function of speed, so the higher the RPM the higher the boost. It is normally the lowest cost solution and has the least efficiency.
The PD (roots) blower makes boost everywhere, if boost is matched at the top end it will make the same power and you get the benefit of the low speed performance. These offer good efficiency and great drivability, but are limited to about 900-1000 crankshaft HP due to the availability of a large unit (largest currently is a TVS2300 - 2.3 Liter)
