LT4 Stingray!!
For anyone wondering the pump harness that plugs into the favors lt1 harness that edelbrock sells comes from Casper electronics...
You also have to grind off the tabs that plug into the factory EVap connector!!! You will know if it's working bc the pump will work and you won't have a check engine light...
if the connector doesmt seat you will get a check engine light and this is also in case the pump stops working!! You'll get a EVap check engine light
Former Vendor
If you guys are looking into doing this. I have a lot of the oem parts you will need.
https://www.corvetteforum.com/forums...post1594798195
