Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Tech/Performance
Reload this Page >
DIY: manual transmission and rear differential fluid service
Old 02-27-2019, 08:28 PM
  #161
phalse
Junior Member
phalse's Avatar
to buy all the crap i need to do this myself and still have nowhere to do it (car cant make it up the driveway into my garage) is silly, so im shopping around local lube places and whatnot...
whats the service manual say about how to check the fluid level in the trans? fill up to just barely below the fill hole as is usually the case? or half inch below? read that somewhere but i think half inch below is the diff.
phalse is offline
Old 02-27-2019, 09:50 PM
  #162
itch808
CF Senior Member
It's the same as most cars, lift car to level, fill until it starts to drain back out the fill hole. Make sure that you're always able to loosen the fill plug before draining otherwise you're going to have a problem.
itch808 is offline
The Following User Says Thank You to itch808 For This Useful Post:
Kracka (02-27-2019)
Old 02-27-2019, 10:08 PM
  #163
Kracka
CF Senior Member
Kracka's Avatar
If you're going to pay someone to do it, pick either a reputable performance shop or the dealership. It's not a hard or complicated process, you just want to make sure it's done with the correct fluids.
Kracka is offline
Old 02-28-2019, 12:17 AM
  #164
okaythen
CF Senior Member
I used the quart pump to pump in transmission fluid in my ford focus st
Amazon Amazon
It's been awhile but some old fluid probably are probably still inside the pump, probably just a little bit, is it ok when it's mixed in with the new fluid and in the vette?
okaythen is offline
Old 02-28-2019, 12:20 AM
  #165
Kracka
CF Senior Member
Kracka's Avatar
Yup, that's fine. Just do a pump or two into the drain pain first to force the old stuff out.
Kracka is offline
Old 03-08-2019, 11:55 AM
  #166
phalse
Junior Member
phalse's Avatar
had the dealership do it a few days ago, requested the leftover be returned to me. guy leaves the gallon jug inside a large clear plastic bag in the passenger floorboard area with the seat all the way forward kinda to prop the bottle so it wont move around. well, ok =D shifting is like night and day.. first to 2nd still leaves something to be desired but is within acceptable parameters now, and all else is like butta, baby. after a cold start i often still find myself going 1st -> 3rd anyway, so, whatever. overall, highly recommended to lose the factory fluid. its just not THAT great.
phalse is offline
Old 03-15-2019, 08:56 AM
  #167
slant6
CF Member
Going to change my dif fluid on my 17 Z51 this weekend, do I need to drive the car a mile or so 1st?
slant6 is offline
Old 03-15-2019, 08:57 AM
  #168
Kracka
CF Senior Member
Kracka's Avatar
It's a good idea to get a little heat into the fluid first; drains easier and suspends the particles in the fluid rather than letting them settle at the bottom and possibly get trapped.
Kracka is offline
Old 03-16-2019, 04:35 PM
  #169
ALEXAMES
CF Senior Member
ALEXAMES's Avatar
2014 M7 3LT, Z51 here with 61k miles.
Transmission and rear end fluid never changed. M7 shifts perfect!
Changing the fluid tonight..D4 ATF Redline
ALEXAMES is offline
Old 03-16-2019, 04:45 PM
  #170
slant6
CF Member
Almost all done.... everything was going great fill hole out no problem got out 2 1/2 quarts as expected ,when opening 3 rd quart it had no aluminum seal at opening (not good with someone with OCD). Got in touch with Ebay seller and claims that bottle came from an older batch B/4 AC delco put aluminum seal
WHAT WOULD YOU DO?????????
slant6 is offline
Old 03-16-2019, 05:11 PM
  #171
ersatz928
CF Senior Member
Don't use it...if you can do without your car until a fresh bottle arrives...
ersatz928 is offline
Old 03-16-2019, 06:22 PM
  #172
Kracka
CF Senior Member
Kracka's Avatar
I've never seen an aluminum seal on any of my ACDelco bottles.
Kracka is offline
Old 03-16-2019, 06:25 PM
  #173
slant6
CF Member
Now I am really confused
slant6 is offline
Old 03-16-2019, 06:28 PM
  #174
Kracka
CF Senior Member
Kracka's Avatar
I'd believe an old batch. I have 3 bottles at home that I just purchased and can check them tomorrow for you.
Kracka is offline
Old 03-16-2019, 06:40 PM
  #175
Pyleit
Junior Member
Id use it. I just checked mine on the shelf. No aluminum seals.. ill be swapping fluid next week
Pyleit is offline
Old 03-16-2019, 08:39 PM
  #176
slant6
CF Member
Pyleit,when did you buy yours?
slant6 is offline
Old 03-17-2019, 01:59 AM
  #177
Pyleit
Junior Member
18 months or so ago i bought a case. These are the last 3 i have from that case.
Pyleit is offline
Old 03-17-2019, 10:14 AM
  #178
slant6
CF Member
Seller said AC delco just started using aluminum seals 6 months ago, lets see what kracka sees on the bottle he just bought
slant6 is offline
Old 03-17-2019, 10:23 PM
  #179
Kracka
CF Senior Member
Kracka's Avatar
My bottles are sealed with a plastic ring around the neck like a plastic bottle of soda.
Kracka is offline
Old Yesterday, 06:42 AM
  #180
slant6
CF Member
With aluminum? (told you I have OCD) lol
slant6 is offline
Quick Reply: DIY: manual transmission and rear differential fluid service
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
