Functional rear diffusers
Sr.Random input generator
I've been looking into functional diffusers, since they reduce drag without adding more drag. So far I could only find two:
Difflow C7 rear diffuser ($829 MSRP)
http://www.difflow.com/corvettec7diffuser.html
APR rear diffuser with undertray ($1965 MSRP):
http://shop.aprperformance.com/index...product_id=423
What do you guys think? Is there anyone with any experience with any of these in terms of aerodynamic impact to the car?
Are there any other functional diffusers available?
Difflow (06-07-2016)
Difflow (06-08-2016)
Just ordered the Difflow unit! Looking forward to installing it : )
Received 1,762 Likes
I think what you meant to say was "A diffuser adds downforce without increasing drag". It does so by creating a low pressure zone at the rear of the car thus pulling it down, somewhat similar in effect to an upside down airplane wing. To work most effectively the underside of the car needs to be smooth without obstruction interrupting airflow to and through the diffuser.
I like the look and the install of the Difflow unit. Does anyone have an idea about the functionality of the diffuser? Does anything need to be done up front to balance the handling? Does this interfere with cooling (factor or aftermarket)?
http://www.racecar-engineering.com/t...-aerodynamics/
http://www.rapid-racer.com/aerodynamic-upgrades.php
