Questions regarding C7 T1 Suspension by GM
I know the kit part number 23336064 is for non-MRC cars. It includes sway bars, shocks, LCA, etc... I've called around and no one seems to have individual part numbers.
I have a 2014 Z51 MRC. I'm trying to see if just the sway bars and LCAs are improved for track over my stock setup. A GM sales rep told me the sway bars and LCAs in this package are the exact same as my current stock MRC sway bars/LCAs. I watched a C7 non MRC with T1 suspension drop 6 seconds off VIR track time vs stock Z51 MRC car with the same driver, same day, same lines, same tires, etc... I can't imagine how that can be correct that the only difference to my car are the T1 shocks. I'd like to buy the kit minus the shocks, but I'm sure GM would say they only work as a complete kit.
Does anyone know the individual part numbers? Are the T1 sway bars adjustable? Can you buy them separately? Thanks in advance!
T1 spec cars run on slick racing tires. Are you sure that the one that you witnessed had the same tires as the Z51? The slicks are probably good for 3+ seconds per lap over the stock tires.
The Z51 T1 suspension car did have slicks. However, the T1 suspension definitely stiffens the car compared to mine. My car is extremely soft in off camber cornering. I run PTM in Race Mode. T1 sway bars IF different than mine would maintain my warranty and hopefully firm up the suspension.
I have gone through all the stock model swaybar variations and finally purchased the aFe bars which are significantly stiffer than the stiffest stock bar. With the stock bars I did not like the softness at turn-in. With the double adjustable front aFe bars that softness is gone, even when left in the softer position. I have not even tried the stiffer position as the soft one is sufficient for me. The triple adjustable rear bars are in the mid position. With that adjustment, I get responsive transitions in canyon driving. For track it would worth exploring the stiffest settings.
Sr.Random input generator
The sway bars and shocks are different part number. The LCAs have the same part number stamped on them as stock, but they actually come with different bushings on them.
Regarding use of slicks: The MRC cars will feel too soft when used with tires that provide better traction than stock. In your case, I'd first recommend that you switch to FE3 springs, which are what T1 kit is also designed for. FE3 is much stiffer than your FE4, and should help immensely.That said, your MRC shocks will then be underdamped, and that will hurt your performance. There is an aftermarket device, provided by DSC motorsports, which could help you tune the MRC to match the stiffer springs.
I'd suggest that most of the lap time differences were due to the slicks. As to the suspension softness; yes, particularly the stock sways are kind of soft. Particularly the front bar.
Your bars sound like a great option. Thanks!
Just checked the T1 part numbers: Front 20959434 (which didn't return the right part when I looked up) and rear 22936510. Indeed, rear bar seems to be FE4 stock bar!
For the price, I'm leaning towards aftermarket as a more tested setup for an MRC Z51. Disappointing GM has no interest in providing track suspension upgrades for MRC cars, but they promote it as the better track car.
Nice find! Ironic that these gm parts dealers can't find the part numbers. The front bar part shows up online titled as GM Shaft.
Well, Bilstein or Penske coilovers lower the car about 1".
I would suggest choosing spring rates from these:
Front/Rear
600/750
650/800
700/850
Of course the Corvette, with stiffer rear springs than front springs, does use a bigger front swaybar.
If no lowering is wanted then the setup might try the C7 Z07 springs with Penske single-adjustable non-coilover 7500 shocks. Or use an aftermarket electronic shock controller for the shock setup. (One reason for stiffer springs without lowering is to stick the 335/30-18 rear tire out the fender on a 18 x 12 66mm rear wheel. See, the 18 x 12 rear wheel will not fit around the suspension at 79mm offset and so it has to go out the fender at 66mm to 62mm offset.)
Front/Rear
600/750
650/800
700/850
There are those who even think stock Z51 (FE3) is unbearable for the street, so this is not an easy question to answer. In my opinion, it is pretty similar to stock suspension, except when the surface gets very uneven (like train tracks, etc.), where you feel the additional harshness. It uses the same springs as FE3, and the sways are about 40% stiffer, while the stiffer bushings might also have a marginal impact, but probably not that much noticable. I don't think it would be harsher than a car with, say, LG sway bars, which are also significantly stiffer than stock bars.
Driven on the street my experience has been that it's not unduly harsh or choppy, really, not degraded in ride quality compared to the Z07 suspension. Compared to a Z51 car, yes definitely stiffer. My previous car was a Z51 C6 with the T1 installed.
In any case, a notable difference is noise and vibration. The T1 takes all the compliance out of the attachment points so you do get clanks and bangs along with some road surface vibration. I don't find it objectionable but others may have a different view. I've driven the car from my home in Syracuse to Watkins Glen multiple times, a distance of 100 miles or so, and found the ride quality and comfort to be acceptable.
Good luck with your upgrades.
Interesting thread, One thing you guys may be missing is I am pretty sure the MRC suspension has softer springs the the stock z51 suspension. Thats why the T1 is for the non MRC suspensions. If you look at the part numbers of the springs, they seem to have different numbers. If you think about it, how would the MRC suspension be able to provide a softer ride if the springs were as/more stiff of the stock z51 without MRC with just a difference in the shock damping? ......I learned early on that tires set you spring rates, and your spring rates set you damping requirements. MRC allows GM increase compression damping when needed and that acts as a increase in spring rates. In no way would MRC be able to make a spring feel "softer" by changes in damping.
Long/ short of it, we need one of you guys with deep pockets to pickup some different springs and try them out. By my math, the z06-07 should have the stiffest spring rates( you know, the grippier the tires, the stiffer the springs).
I have a non-mag Z51. Does that mean I already have T1 springs and rear bar?
