Thoughts on a new shifter
Old 09-03-2016, 06:38 PM
Proudpatriot
Proudpatriot's Avatar
Default Thoughts on a new shifter
Overall I am enjoying my 2016 Stingray. I have two complaints. One is the stupid skip shift and the other is the sloppiness of the shifter. Today my husband installed the shift skip eliminator so one complaint should be fixed. Just to prove that he really loves me he told me he would replace the shifter later this month (my birthday).
I am familiar with Hinson, MGW, and Hurst. My husband had a lot of problems with the Hurst in his Challenger so he wants to avoid it. What are your thoughts on the Hinson and MGW?
The car is my daily driver if that matters.
Old 09-03-2016, 09:12 PM
Elite275
Elite275's Avatar
Hands down MGW
Proudpatriot (09-04-2016)
Old 09-03-2016, 09:58 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
MGW!!!
Old 09-03-2016, 10:32 PM
555ctsv
555ctsv's Avatar
I installed the Hinson first. It rattled and transmitted a lot of vibration into the palm of my hand. Returned the Hinson and replaced with MGW. I know MGW has a million fans on this forum and now i know why.
I also recommend MGW
Old 09-04-2016, 12:20 AM
Iceman09
Iceman09's Avatar
St. Jude Donor '17
Swapping the stock shifter for MGW was one of, if not the best mod I have done. So precise now!
Old 09-04-2016, 06:15 AM
RipcordZ51
RipcordZ51's Avatar
Proudpatriot (09-05-2016)
Old 09-04-2016, 10:11 AM
juanvaldez
juanvaldez's Avatar
Same here.
Old 09-04-2016, 02:01 PM
TNSQUIRE
TNSQUIRE's Avatar
MGW. Awesome product!
Old 09-04-2016, 11:15 PM
skvette
skvette's Avatar
Cruise-In VIII Veteran
Hinson. I had the MGW and sold it for the Hinson. It makes a little noise once in a while but the shifting is much better.
The following 2 users liked this post by skvette:
Proudpatriot (09-05-2016), thrilled (09-14-2016)
Old 09-04-2016, 11:58 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
I put the MGW in almost a year ago and have been really happy with it. A few months ago I swapped the stock shift **** for their flat stick and cue ball, it's made this really solid mod even better. I definitely recommend it:
Old 09-05-2016, 08:00 AM
Former USMC
Former USMC's Avatar
Greetings,
I think I had less than 500 miles on my 2016 before I swapped out the shifter for the MGW - the first time I shifted, I was amazed at the difference.
My Shark Gray is also a daily grocery getter and the MGW is the only way to go. I can't believe Chevrolet would actually put a sloppy shifter in their Corvettes.
Regarding the CAGS Skip Shift Eliminator - yes, I installed one as well. You'll still see the warning, but you can easily shift into second at very low speeds. A simple plug and play (or shift in this case).
Proudpatriot (09-06-2016)
Old 09-06-2016, 07:50 AM
Elite275
Elite275's Avatar
Are you sure this is installed correctly? I installed one prior to tuning my car and the warnings also went away.
Old 09-07-2016, 06:43 AM
Former USMC
Greetings,
Pretty sure it was installed correctly - thought there was only one way to plug it in. I was informed by another forum member that you would still see the warning, but the CAGS SSE would allow you to shift into second.
Semper Fi
Old 09-07-2016, 06:47 AM
Proudpatriot
Mine still shows the warning but I can shift into 2nd.
Old 09-07-2016, 05:01 PM
TEXHAWK0
TEXHAWK0's Avatar
What Hurst shifter did your husband have?
I tried the Hurst billet shifter in my C5 Z06, but the throw was a bit too short.
I switched to the Core Shifters modified Hurst shifter, and still like it so much I transferred it to my 2014 Stingray. Throw is about the same as stock but it is a good compromise between precision and shift effort..It uses Hurst internals from Hurst billet plus 2 shifter, and Hurst stick.
The main reason I stayed with CoreShifters model is I like the retro look of the old school rectangular Hurst stick and ball..
The Hinson shifter is a shorter throw and you WILL see an increase in shift effort over the stock and MGW. Even MGW realized that making the throw too short can cause other problems so they back off on later models. Really, the stock throw of about 3 inches is a good compromise.
Old 09-07-2016, 05:56 PM
Proudpatriot
I don't know which Hurst he had. He doesn't have that car anymore. He liked the look and feel of it but the part wasn't machined right and he couldn't install it. After calling the company he got a part that fit but it rattled and he was always messing round with it. He got a new Challenger and he likes the stock shifter.
He said he won't put the Hurst in my car. He has heard good things about the MGW.
Old 09-08-2016, 04:58 PM
Damian M
Damian M's Avatar
Thank you for advice, I just ordered mine today after reading your message. I also went with the flat stick, charcoal grey and black ball.
To Thoughts on a new shifter
Old 09-08-2016, 06:12 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
MGW are the Hinson you will not go wrong with in the car. But I like the MGW the way it worked in the c7 but not drove one in a c7 in the Hinson yet. Only going from one in a c5 & c6 car...
Old 09-08-2016, 07:17 PM
555ctsv
555ctsv's Avatar
Same one i did
Old 09-14-2016, 01:53 PM
SpeedyD
SpeedyD's Avatar
Hands down MGW
I just went through he same dilemma as I didn't like the sloppyness. Did the research and 90% of the people said MGW. I purchased it, install went smooth, about 2 hours taking my time to make sure everything was perfect. Major difference and all slop is gone and the shift is much more precise. You can order right from their website for $360.00 plus shipping. I was able to find a 10% discount when I did mine so maybe you can locate that.
Good Luck, Dan
Quick Reply: Thoughts on a new shifter
