C7 3:90 & 4:10 Gears
#181
Received 1,762 Likes
A320Flyer (01-09-2019)
#183
Received 1,296 Likes
2018 C7 of Year Finalist
Out of curiosity, will this change the trap speed of a car as well? It makes sense to me as you are in your power band much more, therefore making more power longer. But I am not very experienced with gear ratios.
From an online calculator, I put in at 7000rpm with a 4.10 ratio and 28.5” tire diameter, it came up with a top speed of 144mph. And currently on my set up I cross the line at ~141mph @6815rpms which is very close to my redline in 4th. Would I be better off doing a 3.90 ratio instead which gives me a top speed of 152mph in 4th? Assuming a 141 trap, I’d cross the line at ~6483rpm which is better than the 5700 I’m currently crossing at. Should note, my power begins to fall off at 6700.
#187
I got a different answer from other person at RPM. He said Motive Gear was the only source and it would be at minimum a year away. He sounded like he knew what he was talking about.
Wish I received better news...
would love to have 4.10s.
What a dream they were to drive in my stick shift C6.
phantom1 (01-12-2019)
#189
Received 3,043 Likes
St. Jude Donor '05
know there is epa stds but holy cow what performance car comes with a 2. or low 3. anything? Girly!
#192
An accurate dyno graph in several gears and some PUC calculations will get you even closer to the best shift points for et as well. I like to try and be very accurate and account for all parameters less obvious like tire growth, etc. But for most cases a good general educated estimate is fine.
#198
#199
