NPP on base C7
Old 11-02-2016, 08:46 AM
frankc5r
frankc5r's Avatar
Default NPP on base C7
does anyone know if wiring for NPP option is installed on non-NPP
C7 cars. Friend wants to install NPP exhaust. ECM probably won't have
the programming but he can add a mild to wild.
Thanks for any help.
Old 11-02-2016, 12:22 PM
davidtcpa
Go Canes!
Support Corvetteforum!
davidtcpa's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I don't think so.
Old 11-02-2016, 08:00 PM
ErnieD
ErnieD's Avatar
St. Jude Donor '16-'17,'19
Akrapovic makes a control kit that allows use of the NPP exhaust on a C7 supplied without it: http://www.akrapovic.com/#!/car/prod...37&yearId=4241
Ernie
Old 11-02-2016, 08:37 PM
Boiler_81
Boiler_81's Avatar
The wiring is not there. The aftermarket systems are his only choice.
Old 11-02-2016, 09:50 PM
ErnieD
ErnieD's Avatar
Ernie
The Akrapovic control kit intercepts the exhaust valve control signals from the wiring harness in the rear fuse box area and provides the additional wiring to connect to the rear NPP valve actuators. Read their installation instructions for detailed info.
Ernie
Old 11-03-2016, 12:24 PM
grumpy63
grumpy63's Avatar
I installed NPP on my non NPP car. The NPP valves are always open (loud position), sounds great and was very inexpensive...
Old 11-03-2016, 04:06 PM
TEXHAWK0
TEXHAWK0's Avatar
I think the actuators are electric on the C7 (unlike the C6), so it seems it might be possible to just run a manual switch to the actuators to close them when you do not want them open.
The C6 system uses an electrical solenoid to control vacuum to the actuators.
Looks like the add on controller system uses a CAN (Controller Area Network) sniffer to detect the car's signal to close the valves, which triggers a relay to provide the electrical signal..
Old 11-05-2016, 11:51 AM
Boiler_81
Boiler_81's Avatar
Unfortunately, the actuators are not a simple on off circuit. See this thread: https://www.corvetteforum.com/forums...-retrofit.html
Old 11-07-2016, 09:36 AM
Tech4882
Tech4882's Avatar
I also am looking at this change to my non NPP stingray. It appears there are two ways to go to switch the NPP actuators on or off. One forum member has designed a solution that uses an external switch and an outfit out of Europe has a design that integrates into the CAN bus using a sniffer circuit and operates like the factory system.
You can get the switch design for around $170 usd and the CAN bus version for about $555 usd. I think plus shipping on both. PM me if you would like additional details. Most of the details are available on other posts on the forum.
The CAN bus version is only available when you purchase the exhaust system provided by the same company.
Old 11-08-2016, 07:19 PM
red 1
red 1's Avatar
Do you know who is selling the $170.00 kit?
Old 11-09-2016, 12:20 PM
Tech4882
Tech4882's Avatar
Check out these posts;
https://www.corvetteforum.com/forums...etrofit-8.html
Old 11-10-2016, 12:26 PM
ErnieD
ErnieD's Avatar
Ernie
Ernie
The control kit is available as a separate item without purchase of a complete Akrapovic exhaust. Check with forum vendor RPI Designs for details.
Ernie
Old 11-10-2016, 02:30 PM
Tech4882
Tech4882's Avatar
The HRE/Akrapovic rep told me the kits were not available for purchased separately, only as replacement items for owners with the Akrapovic systems on their vehicles.
Apparently not correct. RPI designs list these kits for sale.
Old 11-18-2016, 01:50 PM
C5pilot1
2nd Gear
C5pilot1's Avatar
I reached out to Theta the creator of the module to retrofit base C7's but have not heard from him. Does anyone know if he is still selling the boards , connectors etc?
Old 11-20-2016, 01:23 PM
red 1
red 1's Avatar
I reached out to him a few times without any response, I think I read somewhere that he was going to have to under go chemo. he may not be around anymore. I hope that's not the case.
Old 11-20-2016, 09:44 PM
C5pilot1
2nd Gear
C5pilot1's Avatar
I recall something on that too. Wow I hope that is not the case also.
Old 11-27-2016, 12:13 AM
Trihawk
Trihawk's Avatar
At least one forum member has done this (4th post down):
https://www.corvetteforum.com/forums...y-exhaust.html
Tech4882 (11-27-2016)
Old 11-27-2016, 06:57 AM
Tech4882
Tech4882's Avatar
That's good to know. At $555 for the kit it's good to know it works on the NPP exhaust before you invest. Here's the RPI link;
http://www.rpidesigns.com/shop/item....c-control-kit/
To NPP on base C7
Quick Reply: NPP on base C7
