Anyone try adjustable rear tow link ?
Even with all washers gone I still need a little help getting tow in on c7 with camber and caster set where I want it - all I really need to know does these rear tow links adjust shorter than stock ones , thank you
Mid American motorworks
Received 8,918 Likes
They need to extend further than the stock links. To get more toe in at the rear the tie rods have to be extended because the tie rod attachment point is located behind the hub. The stock links are too short when a lot of negative camber has been set by adjusting the LCA mounts outward.
Bill
Bill
savage (02-01-2017)
Bill
Bill
Sr.Random input generator
I did install these toe adjusters, and they worked great; they let me adjust camber without being limited by Toe going out of whack.
https://www.corvetteforum.com/forums...post1593075047
They seem to have a good build quality, too.
I had those and didn't like them! First, the tapered pin didn't seat up to the collar on the spindle which was not illustrated or mentioned in the instructions that it was not suppose to and I ended up stripping the threads! The stock toe endlinks do seat flush. I've had a few emails with Granatelli about this and they are supposedly changing their instructions. I ordered the AFE/PHADT ones which are more expensive but you can see the quality is outstanding compared to the Granatelli setup. I am not saying the Granatelli setup won't work but the quality is not the same. The AFE/PHADT ones have very detailed instructions compared to the Granatelli. I lowered(slammed) my 15' Z06 on aftermarket bolts and needed adj toe links.
If the Granatelli bars are installed correctly do they work and will they last? If so that is the highest quality you can get.
Quality is reliably doing the job the part is designed to do. Everything else is wasted effort as it produces no added benefit.
Bill
Back when I installed it, it took me a few minutes to realize that they would not seat flush, and the rest was very easy.
Regarding quality, I don't think that has any importance; we should monitor if these toe links lose their adjustment under stress, or buckle/bend; these are the important factors. Mine so far held up well, and survived a few track days.
Saying the quality is better doesn't mean much.
Bill
Bill
