Magnetic ride?
Received 1,298 Likes
Black shocks and wire coming from the top of the shock. You can see the wire easily under the hood.
Also if you go to Track and press the button 2 times you will get 5 different choices from Wet to Race.
Check the manual up in the sticky threads for more info.
The suspension code FE4 on the service parts sticker indicates Mag Ride. The sticker is under the rear carpet near the battery.
Ron
Ron
