Lingenfelter non-turbo upgrade
Old 04-20-2017, 11:18 PM
john4840
Cruising
john4840's Avatar
Default Lingenfelter non-turbo upgrade
I have a 2016 Z-51 and have been thinking about an engine up grade. What do you think ? See below.
600 BHP 500 Lbs ft of torque
C7 Corvette Stingray 378 CID LT1 600 HP 2014-16
Part Number: L011005114
$9,995.00
Package includes:
Engine removal, inspection and cleaning for assembly
Lingenfelter CNC ported & polished LT1 cylinder heads
Hollow stem 2.13-inch intake valves, 1.59-inch diameter exhaust valves
Three angle valve job, hand blending of valve seats
CC chambers, surface, set spring heights and assembly
Lingenfelter dual valve springs, titanium retainers, 10 degree locks
Lingenfelter Aggressive Idle hydraulic roller camshaft by Competition Cams
Ported & polished throttle body
High Flow Green Air Filter
All necessary gaskets, fluids & bolts
Professional assembly & engine installation
Custom engine control module reprogramming
Chassis dyno testing before & after installation
Excellent drivability, highway mileage not adversely affected
Lingenfelter 3 year/ 36,000 mile warranty
Lingenfelter certificate of authenticity
Lingenfelter chrome fender badges, interior badge & personalized stainless engine badge
Four wheel alignment, cleaning & detailing, full tank of 93 Octane fuel before delivery
Deletes factory active fuel management AFM & variable cam timing system
Old 04-21-2017, 07:43 PM
Toombs
Toombs's Avatar
Sounds nice, Do it. Report back on results. Since no forced induction, I wonder if they could leave AFM in? Just curious if any power upgrade can. Not really relevant, just wondering.
Old 04-22-2017, 12:08 PM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
Keep in mind two things:
1) The power gains will be almost exclusively at higher RPMs. Is that where you use your car?
2) You're getting an aggressive idle cam which might compromise driveability.
That's the nice thing about supercharger packages. They add a ton of torque down low where you can use it and don't mess up your existing driveability.
If it were me, I'd save up for a blower. Then you get it at every stoplight. But if you believe that the way you'd USE these mods fits with your driving style (ie: mostly for sound on the street, or to be used at the track), then it'd make sense.
john4840 (04-22-2017)
Old 04-22-2017, 05:47 PM
Michael A
Michael A's Avatar
Received 2,902 Likes on 1,354 Posts
Also some supercharger kits are 50 state emissions legal, so if your area implements smog checks or you move to an area with smog checks, you don't have to worry about the mods. The kits are about $6500 to $8000 plus labor. An example is the Edelbrock E-force. I've not used this one so no first hand experience.
Michael
Old 04-23-2017, 11:07 AM
bigsapper
Support Corvetteforum!
bigsapper's Avatar
Says AFM & VVT delete at the bottom.
$10k is a bit steep, but I'm all about NA. Looks like essentially a H/C package.
____________________
Did a little more looking around, because I've seen H/C for the GenV at half that price in the past. Looks like that is more or less inline with most other offerings today. Plus it looks like they're bundling it with a warranty. Hmm. Something to consider there.
Old 04-25-2017, 09:17 PM
TJC333
TJC333's Avatar
Big horsepower increase but not much of a torque increase over stock. I would rather have a supercharger.
Old 03-26-2023, 09:24 PM
fnbrowning
fnbrowning's Avatar
Has any Corvette Forum member done this package? Any real world reviews?
Old 04-04-2023, 07:03 AM
^&right
^&right's Avatar
I've looked at their packages as well. None of them mention the necessary upgrades to the fuel system, nor improvements to the transmission. I'd sure want an upgraded clutch assembly. Don't know what the auto can handle.
Thoughts?
To Lingenfelter non-turbo upgrade
Quick Reply: Lingenfelter non-turbo upgrade
