Z51 differential oil cooler vs Z06 cooler
Some of us Z51 owners are upgrading their transmission oil cooler to the bigger Z06 cooler (together with the bigger Z06 duct).
We then have the original Z51 transmission oil cooler as a spare part.
This then could be an upgrade for the differential cooler (the Z51 transmission cooler is much bigger than the differential cooler).
Does anybody know, if the Z06 cooler is bigger than the Z51 cooler and if so, if the duct is different as well ?
Even better would be, if someone had the dimensions of the Z06 differential cooler.
Thanks.
Regards
Götz
Thanks.
Regards
Götz
Z51Tim (04-30-2017)
Received 1,762 Likes
ttt
Z06 is bigger one guy in here did the LG coller put also put the stock coller in line with it also.
I did the LG stuff plus the LG oil pan for the trans. You will love the LG stuff all of it work really great man. Robert
I meant the differential cooler and because I will replace my Z51 transmission cooler with the Z06 transmission cooler, I will have the Z51 transmission cooler spare and could use it as an upgrade for my Z51 differential cooler.
I am just not aware if there is any temperature problem with the differential or not. If the Z06 cooler is bigger, than this would be an indication.
Regards
Götz
