Removed Vitesse and still reduced engine power
2016 Z06. No mods other than Vitesse. No track days. Street time only. Okay, this would happen randomly with the Vitesse controller and all I had to do was recalibrate the Vitesse controller. Well it happened this time and I'm unable to recalibrate the controller to fix the problem. I've removed the Vitesse controller completely and this still happens. Has anyone else had this problem?
I also cannot select another Drive mode. Also is there no way to clear DTCs without an external OBD2 reader?
Received 1,762 Likes
ttt
Look at unhooking the batt and let it sit for 15 to 30 mins. On the c7 I don't know the buttons to push on the dash on the reset pad but am sure it can be done on it are like you have said with the obd2 port.
Since you have pulled that part from the car have you unhooked the batt. If not do that like I have said & let the car totally go thur all of its reset stuff. Robert
nightmel (05-15-2017)
If it does something is wrong with a computer like that. That is if you have not had the car to a tuner. 100% of the time that has something to do with the VE table in the fueling. Are anyway it did in the c5 & c6 with a bad tune. But hope for you it was that part you put on it that was are had to give the TB a bad reading... Robert
Keep the Controller unplugged and let's see if no CEL / Reduced Engine Power
If it does come back again, then you may need to have your Throttle Body sensor or Gas pedal sensor checked.
Maybe something is wrong and when you install the Controller, it amplifies the issue.
nightmel (05-17-2017)
I love the controller. I've had to recalibrate it a few times in the past 6-8 months, but it just wouldn't clear this time. I hope it was just the car not willing to give up the fault until it was cleared. I definitely want the controller back on.
I had an issue with my Vitesse as well. Would go into reduced power and no throttle. Unplugged it and put the factory harness back in and went away. Haven't have it plugged back in in months and haven't had a problem except now no quick throttle response.
