LT1 Cam Swap Cost?
LT1 Cam Swap Cost?
A mechanic told me I need to do a fuel upgrade if I do a cam swap. Is that true? If so, what would be the cost of something like that?
Received 1,762 Likes
I have NO mechanical aptitude and was wanting to get mod #2 on my '14 Z51 A6. I have Kooks Headers, XPipe, CAI and a tune. Now, I want to do a cam swap.
I have heard prices anywhere from $3K to a Speed Shop telling me I have to do a complete fuel delivery upgrade and will cost $10K
Can someone give me a good window of what a normal cam swap cost would be on an LT1 '14 Z51 A6?
Corvey-licious (06-11-2017)
I'm Batman..
Pro Mechanic
Don't see you need a fuel upgrade on a cam swap only to the car here at all. Now the cost for all the labor & cam & part will run you a good 3,k plus with you having to pay for a tune & turn key let say. A tune will cost you a min of 600.00 cam 400.00 all gasket & part and labor 2,k to 2500.00.. Robert
Vengeance Racing has a "cam kit plus" kit with a cam, with all the add-ons for the cam for $2,000. Plus $600-$800 for a tune, brings you up to about $2,800. Add about $2,200 for install, and yep, you're at about $5,000. Install takes a lot on the LT1 as it requires the engine be lifted or the lower cradle dropped since the oil pan must come off to get the oil pump and timing stuff off..
Corvey-licious (06-12-2017)
Ported MSD intake manifold or ported oem manifold, ported throttle body and flex fuel e85 will get you running pretty stout.
Based on dyno graphs, the MSD carries the power up a little better but the ported oem manifold has it beat everywhere else.
The Edgyvette ported throttlebody and intake manifold is only $500 after core returns.
I really want to cam my car too, but it is so cost prohibitive. To put things into perspective I paid 4K for my new supercharger kit.
Everyone I've talked to stated they'll pull the engine. It's just easier that way. That included quotes on doing a cam in a truck.
Do you have to make any modifications to the car for that? Or is it strictly a tune?
I'm on stock fuel system with a cam and supercharger making 786whp. You don't need to upgrade fuel system for a cam.
Make sure to get a cam with the increased fuel lobe.
I'm Batman..
Pro Mechanic
"The Edgyvette ported throttlebody and intake manifold is only $500 after core returns"
What sort of HP gains could you expect with that upgrade?
And with the E85 tune, do you have to make any modifications to the car for that? Or is it strictly a tune? I had a Speed Shop tell me if I do the E85 tune I have to (again, broken record) upgrade the fuel delivery system since it uses 30% more fuel.
By getting a cam with a 32% fuel lobe, you ARE upgrading the fuel system lol. Still have to do a lash cap though to provide proper preload on the pump
Originally Posted by FYREANT
This is accurate. In order to run E85, you MUST upgrade the fuel system. Some of us can only run about E45 blend since we cannot flow enough fuel after upgrading all the high side stuff.By getting a cam with a 32% fuel lobe, you ARE upgrading the fuel system lol. Still have to do a lash cap though to provide proper preload on the pump
Yes, the lash cap as well.
Complete fuel delivery upgrade not needed.
Increased fuel lobe may not be needed.
My install was defect free.
There are many opportunities for the installer to introduce defects.
Your installer should have done four or five C7 cam installs, before I would let him do this modification.
From a quick search with everything I recommended you can expect to dyno 470-480whp and run very low 11s @125mph.
Reach out to Edgyvette to get the real answer on e85 fueling needs. I'm certain you don't need any upgrades. I don't think I would trust a tuner that doesn't know his stuff.
$5,000, installed, and tuned.
$400 for a cam alone? you're forgetting you need to pull the heads to change the valve springs, installer the phaser limiter, change the lifters and trays, etc. your tune pricing is pretty accurate though..
OP here if me & going to this point on a cam I would also do a set of pistons in the car also. Robert
Wow... five grand to install a cam. That was the second serious mod I ever did, back when I was 16, and it took me an afternoon, some hand tools, and about $300... on a 1969 Pontiac, that is.
Clearly swapping the cam in a C7 is a little more invasive and difficult!
Long gone are the days when you could rebuild 75% of a Chevy with a 9/16" wrench and a screwdriver!
Kbarker12 (04-07-2023)
I'm Batman..
Pro Mechanic
But you have to drop the pan to swap cams.
Two steps forward, one step back.
I just did exactly what you want to do. I had a mild cam installed, along with the E85 flex fuel sensor and a mild tune as I drive the car everyday! cost was $3500 out the door with me purchasing the flex fuel sensor. 2014 Z51 A6.
With a very conservative tune, I put down 477hp, 465 Tq.
Good Luck
Good Luck
It's funny because I'm in two threads at the moment - this one, where it costs $5000 to change a cam, and one in the C7Tech forum where they're saying you can upgrade an LT1 to LT4 power for $6000. Unlikely that both can be true!
I'm Batman..
Pro Mechanic
Not exactly. You can buy a blower kit, headers, and meth for $6000 if you do the install yourself. You could even squeeze a tune in there under $6k. That will get you to Z06 power.
Parts and labour on a blower install to go from LT1 to LT4 power runs more like $20K (my brother did that on his Camaro, a neighbor did it, pretty common). That's the drycleaner (drop off, pick up later) version of it, anyway.
