At what crank angle should cylinder pressure peak for max work? - CorvetteForum - Chevrolet Corvette Forum Discussion
C7 Tech/Performance
Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Old 06-17-2017, 01:10 PM   #1
DAVE396LT1
CF Senior Member
DAVE396LT1's Avatar
Default At what crank angle should cylinder pressure peak for max work?
Piston reaches "0" speed at TDC and BDC, and you have maximum piston speed at 90 degrees past TDC.
I can't seem to find a reference for where you want the cylinder pressure to peak for ideal maximum power production (ie: best ignition timing).
Maybe there's fancy calculus involved in it because the pressure graph isn't symmetrical, but there still must be some angle over which it's centered.
When you look at graphs it seems to be somewhere in the 12-20 degree range, but that's pretty wide.
Help me hardware people, I'm a software guy!
DAVE396LT1 is offline   Reply With Quote
Old 06-18-2017, 05:25 PM   #2
Larry/car
CF Senior Member
Larry/car's Avatar
Different RPMs will change the advancement, remember the centrifical advance of mechanically timed ignition. As the RPM increased the ignition advanced accordingly. I would think the computer also advances the spark according to a multiple number of inputs. Why are you concerned?
Larry/car is offline   Reply With Quote
Old 06-18-2017, 06:11 PM   #3
DAVE396LT1
CF Senior Member
DAVE396LT1's Avatar
Quote:
The optimal angle is constant (I think - assuming the plot of pressure is symmetrical but I don't know for sure that it is). The amount of advance needed to hit it accurately changes with conditions, that's all. I'm not asking how much advance is required to hit the optimal, I'm asking where the optimal is.
I think it's somewhere around 23 degrees ATDC, but:
a) First I want to confirm where optimal is,
b) Then I want to understand why it's wherever it is
That way I'll have my ducks in a row next time I need to explain why advancing timing (can) cool the engine, but I'd like to have this fact squared away in advance (no pun!).
Sure lots of opinions on chrome wheels and automatic transmissions on this forum compared to the amount of physics help :-)
This article makes it sounds like 16 degrees is ideal, and the amount of lead varies to hit it:
https://www.jcmmachineandcoatings.co...ng-combustion/
Old 06-19-2017, 02:05 PM   #4
DAVE396LT1
CF Senior Member
DAVE396LT1's Avatar
Here's a chart that shows it at 15 degrees, but there's no explanation. I know that maximum leverage is at 90 degrees, but what's magic about 15?
I found a different source that says you're trying to target 15-20 ATDC, but again it doesn't explain why:
Best explanation I can find so far says that point is indeed constant for a given engine, but that it varies based on engine geometry:
"Many experiments have shown that the optimum position for this pressure peak is about 15 to 20 degrees after TDC. The exact location of the optimum pressure peak is actually independent of engine load or RPM, but dependent on engine geometry."
The Following User Says Thank You to DAVE396LT1 For This Useful Post:
cam30era (06-19-2017)
Old 06-19-2017, 04:38 PM   #5
Suns_PSD
CF Senior Member
I've actually measured this on a diesel truck making 650ish about 15 years ago using in cylinder pressure transducers. We settled on 4-5 degrees ATDC as the ideal peak. Fuel takes time to burn and peaking too late means a lot of that force is wasted. Too early is hell on hard parts.
Suns_PSD is offline   Reply With Quote
Old 06-19-2017, 05:07 PM   #6
goec2468
CF Member
Quote:
Since diesel is burning slower than pertol, the ideal point of peak pressure is earlier in diesel than in petrol engines.
For a small block chevy I read the ideal point to be 15°.
Regards
Götz
goec2468 is offline   Reply With Quote
Old 06-19-2017, 05:28 PM   #7
Suns_PSD
CF Senior Member
I thought of that, and you certainly might be correct. However, that old diesel only spun up to 3200 rpm or something. I dunno.
Old 06-19-2017, 08:35 PM   #8
cam30era
CF Senior Member
cam30era's Avatar
Typically, for most spark ignition homogeneous charge engines, crank angle location of peak pressure at maximum torque is about 8 degrees after Top Dead Center. This is driven from typical combustion duration of 30 to 45 degrees.
cam30era is offline   Reply With Quote
Old 06-20-2017, 04:16 AM   #9
goec2468
CF Member
The slow burning rate is the reason why even modern diesel engines don't go beyond app. 5000 rpm.
There is simply not enough time to burn the diesel efficiently.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • At what crank angle should cylinder pressure peak for max work?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    HOW TO: Degree Your C7 LT1 Camshaft! FYREANT C7 Tech/Performance 1 05-29-2017 08:06 AM
    [Z06] Valve Events to Determine TDC geezel C6 Corvette ZR1 & Z06 15 01-20-2017 01:12 PM
    AFR on pump gas plus meth jon6.0 C6 Forced Induction/Nitrous 35 02-08-2014 04:46 PM
    What I've Learned in My Search for a Torque Cam for my LS3 Nexus9 C6 Tech/Performance 15 12-12-2011 08:46 PM
    Technical ramblings..exhaust scavenging, LSA, lift, duration, X pipes(LONG) Phil97SVT C5 Tech 8 02-15-2003 11:16 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    Question Title:
    Description:
