[VR] Vengeance Racing Camshaft Kits - REDUCED PRICING AND UPDATED PARTS!!!
Former Vendor
In our 11 years of business, we have found that the aftermarket camshaft is truly the backbone of modifications on most any LS and now LT powered vehicle that we've encountered. For that reason, we have put in countless hours on research, design, and development of our custom spec camshafts and camshaft kits to ensure that each of our customers receives a combination suited to their goals and needs. Due to our dedication to providing not only the best possible products but pricing as well, we are announcing new lower pricing on all of our camshaft kits for both LS and LT engines! We have also finished putting together a "Budget Cam Kit" for the Gen V LT engine platform for those who only need the basic items for our aftermarket camshafts for their C7 Corvette, 2014+ Truck/SUV, 2016+ CTS-V, or 2016+ Camaro SS/ZL1. Please take a look below at all of our new pricing, as well as parts offerings in each kit. We also have "a la carte" camshafts available for those only needing the perfect camshaft for their engine project! Lastly, we also offer a custom camshaft order form (linked below) if one of our off-the-shelf camshaft grinds do not meet your exact needs, or if you have a very unique combination.
Vengeance Racing Budget Cam Kit for LS Engines
Originally $799.99 - NOW STARTING AT $699.99!
Vengeance Racing Budget Cam Kit for Gen V LT Engines
NOW STARTING AT $899.99
Vengeance Racing Cam Kit Plus for LS1/2/6 Engines
Originally $1,349.99 - NOW STARTING AT $1,249.99!
Vengeance Racing Cam Kit Plus for LS3/LSA Wet Sump Engines
Originally $1,399.99 - NOW STARTING AT $1,299.99!
Vengeance Racing Cam Kit Plus for LS3/7/9 Dry Sump Engines
Originally $1,249.99 - NOW STARTING AT $1,099.99!
Vengeance Racing Cam Kit Plus for Gen V LT Engines
NOW STARTING AT $1,999.99!
Vengeance Racing Cam Kit Plus CONVERSION for DOD/VVT Equipped Engines
Originally $1,999.99 - NOW STARTING AT $1,899.99!
VENGEANCE RACING CATHEDRAL PORT CAMSHAFTS
Vengeance Racing VRX1 220/220 .581/.581 114+4
Vengeance Racing VRX2 224/228 .581/.588 114+4
Vengeance Racing VRX3 226/228 .585/.588 114+4
Vengeance Racing VRX4 228/230 .588/.592 112+4
Vengeance Racing VRX5 236/238 .601/.605 113+2 **#1 Selling LS1/2/6 Camshaft**
Vengeance Racing VRX6 238/240 .605/.609 112+4
Vengeance Racing VRX7 244/248 .612/.598 114+4
Vengeance Racing Vindicator 240/244 .601/.596 112+4 **MAX PERFORMANCE Cathedral Port Camshaft**
VENGEANCE RACING LS3 SQUARE PORT CAMSHAFTS
Vengeance Racing VRSP-1 223/227 .610/.614 114+4
Vengeance Racing VRSP-2 227/235 .614/.621 115+4 **#1 Selling LS3 Camshaft with Stock Torque Converter**
Vengeance Racing VRSP-3 239/247 .624/.624 114+4
Vengeance Racing VRSP-4 247/251 .624/.624 113+4
Vengeance Racing KAOTIK 235/243 .656/.660 113+2 **#1 Selling LS3 and LS7 Camshaft**
VENGEANCE RACING LS7 CAMSHAFTS
Vengeance Racing Annihilator 239/251 .660/.660 113+2
Vengeance Racing SumBich 247/258 .661/.652 112+4 **MAX PERFORMANCE LS7 Camshaft**
VENGEANCE RACING FORCED INDUCTION CAMSHAFTS
Vengeance Racing VRPD-1 (for positive displacement superchargers) 223/239 .610/.623 118+4
Vengeance Racing VRPD-2 (for positive displacement superchargers) 231/239 .617/.624 118+4 **#1 Selling LSA Camshaft**
Vengeance Racing VRSC-1 (for centrifugal superchargers) 223/231 .610/.617 115+4
Vengeance Racing VRSC-2 (for centrifugal superchargers) 231/239 .617/.624 115+4
Vengeance Racing VRTT-1 (for turbocharger applications) 227/223 .614/.610 115+4
Vengeance Racing VRTT-2 (for turbocharger applications) 235/231 .621/.617 115+3
Vengeance Racing ZR1-E (LS9 Specific) 235/247 .621/.624 115+4 **#1 Selling LS9 Camshaft**
VENGEANCE RACING CUSTOM CAMSHAFT ORDER FORM
Please feel free to call us at 678-513-7105 or e-mail sales@vengeanceracing.net with any specific questions or for assistance in placing your order or scheduling an appointment for install!
- Vengeance Racing Custom Camshaft of Your Choice
- Vengeance Racing Hardened Pushrods
- BTR .660" Lift Dual Spring Kit
- Vengeance Racing Gen V Camshaft of your choice w/ 32% fuel lobe
- BTR .660" or .685" dual valve spring kit
- Vengeance Racing 3/8" hardened pushrods
- Vengeance Racing 5/16" Hardened Pushrods
- BTR .660" Lift Platinum Dual Valve Spring Kit
- C5R Timing Chain
- Melling Hi Volume Oil Pump - 10296
- Comp Cams Trunion Upgrade
- GM Front Cover Seal
- GM Front Cover Gasket
- GM Waterpump Gasket Set
- GM Crank Bolt
- ARP Cam Bolts
- Vengeance Racing .660" Lift Dual Valve Spring Kit
- C5R Timing Chain
- Melling Hi Volume Oil Pump - 10296 or 10355
- GM Crank Bolt
- ARP Cam Bolts
- LS7 Timing Gear
- LS2 Dogbone Timing Damper
- Cam Kit Plus Includes all items listed below
- Vengeance Racing 5/16" or 3/8" Hardened Pushrods
- C5R Timing Chain
- GM Crank Bolt
- ARP Cam Bolts
- Vengeance Racing Custom Camshaft w/ 32% Fuel Lobe Upgrade
- BTR .660" Lift Dual Valve Spring Kit w/ Ti Retainers
- Vengeance Racing 3/8" Hardened Pushrods
- C5R Timing Chain
- Fuel Pump Lash Cap
- CompCams Trunion Upgrade
- CompCams Phaser Limiter
- GM VVT Cam Bolt
- GM Crank Bolt
- GM LS7 Lifter Set
- GM Lifter Trays
- GM MLS 6.2L Head Gaskets
- GM LT Exhaust Gaskets
- DOD Delete Plug Kit
- ARP Cylinder Head Bolt/Stud Kit
- Vengeance Racing 5/16th Hardened Pushrods
- C5R Timing Chain
- Melling Hi Volume Oil Pump - 10355
- GM Crank Bolt
- ARP Cam Bolts
- LS7 Timing Gear
- LS2 Dogbone Timing Dampner
- GM LS7 Lifter Set
- GM Lifter Trays
- ARP Gen IV Head Bolt Kit
- GM MLS Head Gaskets
- LS2 Valley Cover
- LS2/3 Front Cover Kit
