Z51 size front rotors on base stingray
I'm Batman..
Pro Mechanic
https://www.corvetteforum.com/forums...-stingray.html
Ant
You only need the front caliper, the rear caliper is the same on both the base and Z51 model. I did that upgrade about 3 months ago, but went with DBA 4000 rotors. If you keep you eyes open on the forum, the Z51 calipers will come up for sale on occasion. That is where I got mine. Good Luck. If I can answer any questions, please let me know. Safe Driving, Tony
You might want to look at the cooling ducting as well since you are upgrading to the z51 brakes. I'm putting the ducting in using the base grille rather than changing out grilles. Cooling is always good regardless of which brakes you use.
tcinla (06-26-2017)
Please consider the APRacing braking system that I'm selling here:
https://www.corvetteforum.com/forums...r-c7-used.html
Thank you!
Joe DeSimone
copjsd@comcast.net
