700hp NA Katech 427 LT1 Grand Sport track car
Old 11-22-2017, 04:07 PM
  #41
LT4_CE
LT4_CE's Avatar
I WANT!!!
Old 01-13-2018, 04:34 PM
  #42
timmyZ06
timmyZ06's Avatar
No idle clips from that cam??!!
Old 01-14-2018, 12:28 AM
  #43
SCOTT280@CENTURYLINK
SCOTT280@CENTURYLINK's Avatar
Default idle clip
youtube
GS 427 coming home
timmyZ06 (01-14-2018)
Old 01-14-2018, 06:14 PM
  #44
timmyZ06
timmyZ06's Avatar
Originally Posted by SCOTT280@CENTURYLINK
youtube
GS 427 coming home
This one???
Old 01-14-2018, 07:11 PM
  #45
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
Phenominal video capturing the build progression from start to finish!!
May I ask (since I don't know), what generally causes a gap between HP and Torque, such as for this build 71 lb ft of torque (627/556). What is necessary to close that gap and increase the torque?
​​​​​​​What is more important at this level of performance, HP or TQ?
Thanks in advance!!
Old 01-14-2018, 09:08 PM
  #46
yes
to the clip
Jason pulling out to load car in my buddys trailer.
I do not know why, but that car, especially on full boil, sounds like no other car Iv'e ever heard!!!
Old 01-15-2018, 01:41 PM
  #47
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Thanks in advance!!
What causes the gap between hp and torque? Bore/stroke, cylinder head design, intake/exhaust airflow/design, camshaft/valve events, compression ratio, fuel type, spark/injection events are all major factors. Remember horsepower is just torque over time.
__________________
Contact:
(e) zach@katechengines.com
Old 07-12-2018, 06:54 PM
  #48
tbrenny33
tbrenny33's Avatar
LOVE this package. Very interested in getting it. I had ‘16 Z06, how does this package compare to a stock Z06? Pretty similar in terms of power and delivery?
Old 07-13-2018, 01:08 AM
  #49
bc928
bc928's Avatar
Only question I have is what us the tech looking at with the hand held microscope in the crank case before the timing cover is installed.
Old 07-13-2018, 08:24 AM
  #50
Katech_Zach
Here are a couple graphs:
427 LT1 manual
3 C7 Z06 manual baselines
Old 07-13-2018, 08:27 AM
  #51
Katech_Zach
Piston squirter clearance
Old 07-13-2018, 09:58 AM
  #52
tbrenny33
tbrenny33's Avatar
427 LT1 manual
Thank you for posting those, very interesting to compare. The 427 is so nicely linear, and not so torquey down low, probably makes for a little more useable power and a ton of fun! Also noticed it appears redline is raised! I actually called a couple days ago. I'll be sending you an e-mail for more info soon. Thank you.
Old 07-13-2018, 10:13 AM
  #53
raylo
raylo's Avatar
But what's the mpg? ;-) ;-)
Originally Posted by blue_bomber697
And there it is. The perfect Corvette.
Old 07-04-2020, 12:50 AM
  #54
Eli-Z06
Eli-Z06's Avatar
Default Cost for the Katech 700 HP upgrade
My C7 Z put 710 HP and 748 TQ to the wheels, but I'm seriously thinking about getting a Admiral blue Grand Sport M7 for a track car, then upgrade the motor to this package! Any idea of the cost involved?
Old 07-08-2020, 03:34 PM
  #55
C5-VERT
Support Corvetteforum!
C5-VERT's Avatar
Cruise-In IV Veteran
Slick build so congrats on that. Curios to me it looks like the knock sensor is in the wrong spot on the driver side first pic? I thought it sits up under a metal heat shield up near the top right? Maybe the LT1's are different. Also with all that money in the build going for a fast revving N/A why oh why didn't they remove all that rotating mass from the VVT assembly using your Billet VVT delete? That sucker is 10lbs or close to it vs a 1lb ish for the LS3 replacement sprocket. That would have made it topped off for sure less stress on the valvetrain (chain, etc.) and sure looked nice. Just my thoughts I guess the buck has to stop somewhere unfortunately I was incapable of doing so on my build. So kudos to saving money :-). It's nice to see vid's making it look so easy and quick to pull these motors out lol.
Old 07-12-2020, 10:14 PM
  #56
kutlow
kutlow's Avatar
You guys ever figure out how to tune the 2019 Zr1 head and cam cars?
Quick Reply: 700hp NA Katech 427 LT1 Grand Sport track car
