DSX Flex Fuel Kits - easiest installation there is
I've got everything in stock and ready to roll. Pricing for these kits is $300, and these are the originals supported by me. Installation couldn't be simpler between the wiring harness and the custom fittings that make it a true snap on installation. There's no need to use a wrench either on the fuel line or the wiring harness. Pinning the ECM is still an unavoidable evil, but everything else is super quick. These use 316SS hardline to ensure long life, durability, and complete corrosion resistance against ethanol.
Click the link below to order!
2014+ C7 Stingray DSX Flex Fuel Kit
thanks
Me too. Just wanted to learn more about the tuning part.
sensor bracket to hold
hey guys I installed the sensor and works perfectly but I could not help to notice the sensor is being held solely by the rail line. Please correct me if I am wrong but would that extra weight by the sensor with engine vibration and common driving cause the o-ring in the line to fail and cause a leak? I thought about doing some zip ties to help with the weight but might look crappy, anyone has any thoughts on this?
thanks
heres my dyno sheet ARH long headers intake and e85
thanks
Leaks
I install flex fuel sensor & made a bracket that will help keep secured. This bracket is not ridged but holds extra weight from being hard on fuel connections.
Vicbright (06-04-2019)
And now that I ordered one, what is the best way to get the tune done. No concerns over warranty.
#33
San Diego
#35
Okay, recieved. Quick ship, thanks DSX. Install won't be an issue. For tuning -
Buy an HPtuner? Find someone in Socal? Do it myself with HP tuner?
Planning on other stuff, but slow going. Drive it 150 miles a day and e85 should be interesting. I have done it on many cars before - but older cars that did not benefit as much.
#37
in CA I’m at over 3.70 for premium. I’m not sure if many notice but the car is regularity in knock retard in 91 octane even in normal driving.
Tye e85 is 2.70 tops. E85 is about 30% less btu. So I think it will wash and the car will stay healthier.
#40
