Whinning noise from 2500rpm and above (reving & driving)
Hi
My 2016 C7 started making a whine noise from 2500rpm and above. Its very noticable and loud.
It makes the whining with AC ON and OFF.
Very very slight noise while idiling, but once reving above 2500rpm it whines very loudly
Also it makes it when driving above 2500rpm.
Any idea what could it be? A yone faced similar issue?
Received 8,926 Likes
Do you have a PDR recording demonstrating what it sounds like?
Bill
Bill
Cold or hot makes the same noise? How many miles on the car?
It would help to have a video of it. Does it matter what gear its in?
I wonder if it is the fuel check valve on the stainless line between the engine and fire wall? If you move the line around it should change the noise. Someone else had a video of this issue. You will have to do some searching to find it.
