Increasing reliability of C7 Z51 for HPDE
Old 06-25-2019, 09:09 PM
blueray16
blueray16's Avatar
Originally Posted by quick04Z06
If you want to track you M7 Z51 car, what changes/adjustments should I make JUST for reliability's sake for the long haul?
Thanks.
Heat is the enemy of all internal combustion engines!
For longevity you should consider upgrading your 2015 with the Chevy performance secondary radiator Kit that became stock on all C7's starting with MY 2017. Part #84309470
That addition to my '16 Z51 along with the new OW40 oil reduced max water temps at Watkins Glen from 250 to 207 and max oil from 286 (with M1 15W50) to 259. I also have the Z06 grill which delivers 17% more air.. (be sure to remove the frt license plate along with the usual track prep.
So far this summer water and oil temps have been less than 200* in normal driving. Impressive!
Old 06-26-2019, 12:07 PM
dp201
dp201's Avatar
Originally Posted by X25
Just remove it from the exhaust stream and let it hang by the side. Mine had never caused a problem with that setup.
I understand that there are several hacks available to get around the problem, but I still have a couple of years left on my warranty that I don't want to void it. I just wish that Chevy could (and should) come up with a permanent fix for a problem that proper testing would have identified to begin with. My local Chevy service has been very responsive in fixing the problem multiple times, but Chevy Customer Service has been very disappointing to say the least.
Old 06-26-2019, 12:32 PM
BrunoTheMellow
Support Corvetteforum!
BrunoTheMellow's Avatar
Received 1,396 Likes on 999 Posts
Moving your actuator won't void anything.
Old 06-26-2019, 12:44 PM
RapidC84B
RapidC84B's Avatar
Received 13,153 Likes on 5,984 Posts
Wonder if my Corsa X-pipe reduced heat at all. Car had a good bit of hard use on hot days and never any issues.
Old 06-26-2019, 03:01 PM
dp201
dp201's Avatar
Thanks.
Old 06-26-2019, 05:25 PM
JMII
JMII's Avatar
Received 2,025 Likes on 1,349 Posts
Anyone else see similar results? I assumed the 50 weight would be better on track.
Old 06-26-2019, 06:22 PM
BrunoTheMellow
43 degrees decrease in water temp is bullshit. Ambient temp must have been much lower. GM only quotes 25 degrees and they would quote the highest improvement they could.
Heavier weight oil has no effect on temps. All it does is not get as thin when oil temps are high.
Old 06-26-2019, 09:07 PM
blueray16
blueray16's Avatar
[QUOTE=BrunoTheMellow;1599651023]43 degrees decrease in water temp is bullshit. Ambient temp must have been much lower. GM only quotes 25 degrees and they would quote the highest improvement they could.
I would have to agree. To be clear, I checked the temps for the Glen on June 20 2017 which was the last time i was able to run full sessions and it was reported to be 75*. On June 12 2019 , DIC was showing 72* . Also improved my best lap by 2 sec.over 2017.
I can't explain it. Actually, I now recall having a shop flush the coolant while doing some other work on the car. I later found they filled 50/50 mixture which i flushed and refilled at the correct 20/80 mixture when i installed the secondary rad. That's all I can come up with.
Finally, we haven't had much heat and humidity here so far this summer. But today I went out and ran a few errands in town.
2 or 3 stops, about an hour. 93* and running the AC. Max water temp was 195* max oil was 190* Money well spent IMO
Your results may vary
Old 06-26-2019, 09:56 PM
Casey Clark
Casey Clark's Avatar
[QUOTE=blueray16;1599651928]
How are you getting water temps below where the thermostat even opens (stock is 207 degrees). Did you adjust your fan programming or get a 180 thermostat?
Old 06-26-2019, 10:03 PM
BrunoTheMellow
[QUOTE=Casey Clark;1599652259]
Stock is 194...
Old 06-26-2019, 11:08 PM
Casey Clark
[QUOTE=BrunoTheMellow;1599652323]
Originally Posted by Casey Clark
Stock is 194...
According to the parts catalog, it is not on my '14 Base. Mine is 207. But...it looks like in '15+ cars (Base or otherwise) the thermostat is 194....Crazy.
Old 06-26-2019, 11:29 PM
BrunoTheMellow
[QUOTE=Casey Clark;1599652695]
How is that crazy? It's not very low.
Old 06-26-2019, 11:34 PM
  #33
Casey Clark
[QUOTE=BrunoTheMellow;1599652780]
Because it's the exact same engine in these cars. GM went to the trouble of changing the thermostat and adjusting the fan curve for what reason? 207 is high to me. Maybe even the highest thermostat I have ever had in a car.
Old 07-09-2019, 11:11 PM
  #34
formula80_ca
formula80_ca's Avatar
Originally Posted by Tool Hoarder
PS - I bought Edgy Vette AFM sims expecting mine to fail, but they never did.
Do you still have the EdgyVette solution?
Quick Reply: Increasing reliability of C7 Z51 for HPDE
