BMS filter VS K&N $60 filter Real World
I just received one today. From what I see is it has more pleats but not as deep, base has a larger opening, the end cap could be more uniformed around. I will do a Real World, not seat of the pants or Dyno. Real World is what really what shows if the filter helps , reduces or does nothing compared to a $60 K&N washable. I will do this at the Drag strip, same strip, on very close to the same DA conditions and same amount of fuel. I have my time slips from Sept 22 to compare, I will be running with the same DR's that I dead Hook with and my car is very consistent usually ET /60' and MPH. Base A8 NPP no mods or tune. I really don't see how it could help much if any other than the base size opening does something magic.
Ran last night 1/8 mile under similar conditions with no magic, ran a tad worse at best with the BMS. Best 60' was 1.697 With the BMS vs 1.667 with the K&N. MPH with the BMS Best was 94.82 vs 94.61 with the K&N, Best ET with the BMS was a 7.548, best with K&N was 7.489. So don't expect any Magic with this filter over a reusable $60.00 K&N. Also this week had little to no head wind and the prior time with the K&N was a slightly more.
Johnp94 (10-08-2017)
C2367 (10-06-2017)
all that really maters is what it really does real world 1/4 or 1/8 mile, Dyno and seat of the pants means not much to me. I may give it a try next time I go to run the 1/4 at Fontana and again at Irwindale. Most likely go back to the K&N because don't want run slower. Yes it is pretty much a wash except for the fact you can't wash a BMS filter.
If I understood it right, there were two weeks between the tests, correct?
If that is the case, you can't really compare the results.
The Performance difference between the two filters (if any) will be tiny anyway, maybe 5-10 hp at max.
Maybe the K&N is better, maybe it is not and maybe the difference is even bigger than you meassured.
I don't think we know yet.
5° difference only in air temperature will result in app. 5hp already.
Hunidity is another factor.
If you really want comparable results you Need to test the filter directly one after the other and then the first again, to eliminate factors like engine temp. heat soak,... (A - B -A).
Regards
Götz
Regards
Götz
Exact1 (08-24-2019)
The more I read, the more I think there is really little to no upside to the filters available over the stock setup. The Vararam seems like the best "CAI" option, but at $400, is the gain worth it? Guess individuals will make that decision on a personal basis.
Regards
Götz
Regards
Götz
Yes $400.00 is to high for most likely next to nothing in a increase change in performance over just a higher flow filter. If they where to have that new system for about $300.00 shipped then it may be worth a try but still think you would only see maybe a 1/2 of tenth and a 1/2 mph at the most real world at the strip. Besides it is more impressive to have a stock car that the warranty is not voided on running great times then a car with MODS running just slightly better times on with a voided warranty. Think a ported TB would help more over a CAI at the strip and the price is less then a CAI.
@OP, if you want to send me the the dates/times you ran and the track, I can provide the DA.
The time of the runs on the slips is incorrect, the date is correct. They do not even start racing until 5pm and I do not run until later when it is cooler and the air is still.
I ran 30 minute sessions on a track and my intake temp was damn near ambient temp. CAI don't actually draw in colder air. All they do is have a less restrictive filter, which means you're also going to let more dust and crap in your engine. You know how much money and R&D OEMs put into making more power? Don't you think they'd use these K&N style filters if they actually had no downside?
And the nonsense about making air smoother into the intake or whatever is just crap. It's going through a throttle body and then getting sucked into the plenum. It's all snake oil. The only reason they get any gains is for being less restrictive, but the trade off is less filtration.
It's a paper air filter, $100 is a lot for something that gets tossed in the trash. If you're spending that kind of money, might as well get something washable/reusable that will last the life of the car.
Also- where are you paying $100 for a paper air filter?
4:45pm: 1,855'
5:45pm: 1,646'
6:45pm: 1,488'
7:45pm: 1.389'
8:45pm: 1,257'
FYI, I use this phone app...
http://www.dragtimes.com/da-density-...calculator.php
Some of the information on Drag Times is not correct.
They have my home track listed at 152 ft. elevation.
It's actually 443 ft. Makes a pretty big change in the DA cals.
Density Altitude...
4:45pm: 1,855'
5:45pm: 1,646'
6:45pm: 1,488'
7:45pm: 1.389'
8:45pm: 1,257'
4:45pm: 1,855'
5:45pm: 1,646'
6:45pm: 1,488'
7:45pm: 1.389'
8:45pm: 1,257'
Not suppose to put the K&N in the wash machine?
You spray it with precleaner and let it set and then gently rinse it from the inside out it.
Once it dry's it is good as new!!
the more the fibers more around, the less uniform they'll be, the bigger the gaps it will create.
Best way to find out if your filter is not good enough for your conditions is get a cheap oil analysis done or several over time. Thats what I'm going to do. If they see lots of silicate and such, you have a filter issue.
