C7 Z06 Misfire just above Idle 5836 miles
I recently purchased a 2016 Z06 with Z07 package car has 5836 miles . I kept getting a check engine light so I took it in to be checked out . so far they have checked the injectors , rocker arms & Valve springs & nothing seems to be wrong . the issue has now been escalated to tier two trouble shooting & they are recommending that the Heads be pulled off of the car ! the car is bone stock , I've seen other people have issues with the motors just wondering if I can get some advice as far as what options I should exercise as far as wanting a new motor or asking them to take the car back. Ive had it a total of 33 days and its been in the shop 11 of them.
Keep a logbook of dates that it is in the shop along with paperwork. In the unlikely event you need to lemon law the car later, better to have your details in order and organized up front.
All that said removing the heads isn't cataclysmic, I could do that reliably myself, so a GM tech should have no trouble.
I wouldn't think you have any ground to stand on for a new motor or a new car due to a misfire yet!
Received 1,762 Likes
ASK THEM can they nail it down to just one of the 8 hole, Maybe a bad plug r bad plug wire r being a little off the coil r plug, are even a bad coil. You have said inj good so not that & springs & all.
Spark plugs can fail early on blown engines.......
I had a similar issue at a one mile race. The issue was spark plugs at about 8,000 miles. They look good. The platinum coating wears off, I hear? Below are pics:
As Robert said they need to nail it down to which cylinder (or cylinders) have the issue. The ECM tracks and reports a misfire count by cylinder so it would make no sense for them to be pulling both heads unless it has the odd case of a misfire on both sides.
An engine that runs normally at idle but misfires above that range most likely has a defective coil pack, plug, or connector. If it is actively misfiring while driving the CEL should be flashing during the misfire event; this is standard behavior for the OBD-II system because it indicates a condition where raw fuel (due to misfire) could be entering the cats leading to severe overheating.
Ask me also how I know that a tuner are so called one had my car couldn't get it to run per say at all on its on. Yes would start then just start misfiring like crazy then die. I told him to chg out the plugs in the car. He day after day would say couldn't find the problem but the plugs was good. After over 2 weeks of him saying he has done this & that but no chg I told him I was coming after the car.
He then chg out the plug & car ran like a dream. So get it to someone that can tell you which hole it is & just work on that hole. Are if me & I had the car I would chg out the plug myself & make sure all plug wires are really good on both ends.
Plus also only play around with the plug wires & it feels like it is good on the plug that thing is a bear to fully be on it so you don't get a misfire. Robert
Update
Thanks for all of the replies and info . Unfortunately the dealership has yet to come up with anything & I told them if the have to pull the heads of the car I no longer want it . I called GM customer service and also let them know how I felt about the situation . I’m pretty sure it sounds like I’m Being a Tight A** but this whole situation has kileld my vibe. I have headers , pulley , meth kit & haltech AC & heat exchanger upgrade sitting in the garage that were scheduled to go on this car at the end of November . Luckily for me they weren’t on before it took a dive .
A GM field Engineer has been scheduled to come out this week . I guess I’ll have to wait and see what happens .
Update 3/31
So the computer has been changed as recommend by the GM field engineer they have also changed the tensioner pulley which I have no idea why . I asked them for my money back based on the fact it’s been almost 30 days and they have no idea what is wrong with my car .
