LT1 Cam Choices
#41
I have had some big cams in cars before and still they dont just stall out at a redlight unless you did something to cause it to hisitate, like to much clutch not enough RPm, or something. the stage 3 stuff i have seen is not to radical really. Not like a magic stick 4 in a 346 ls1 haha. That plan sucks
#46
Well its not tuned, and idling ruff down at 600ish... but its cammed! ha
should be finished up tomorrow and hit the rollers. Will update with numbers and proper video.
https://www.youtube.com/watch?v=0Joo...ature=youtu.be
#47
#49
Ok, car is done for the moment. Other then a 160 thermostat they forgot to install.....
It put down 505rwhp / 474 rwtq when it was done. Not bad for a 93 daily driver NA car, it pulls good up top. Drives SUPER easy like no bucking at all which is surprising, could have went bigger....ha But makes for a nice driver for sure. can even hold 7th at 55mph with out bucking so that's impressive.
Made a quick walk around at lunch since it was clean, and warmed up.
#53
My bad that is what i ment "stock". but just asked the tuner to be sure and:
6600 is stock fuel cut in gear, and its now at 6800, so raise it 200 rpm
Peak power was @ 6400 RPM.
Out of gear fuel cut is still 6600 (stock).
FYREANT (12-11-2017)
#54
Ok Money spent.
Car should be over 500rwhp when done (Somewhere in the 500-520rwhp/460-475 TQ with these mods)
Should be a good driver not to much over lap 4.5 degrees, the cam is also boost friendly incase I find a LT4 blower cheap later on. and sound like the video below.
Parts ordered:
Brian Tooley Racing Stage 2 Cam (227/242 .637/.626 @ 115+6)
Brian Tooley Racing .660" Lift Platinum Spring Kit
Brian Tooley Racing LS Chromoly Pushrods
Brian Tooley Racing Titanium Retainers
New Locks, and Valve Seals
CBI Streetcars Gen IV/V DOD Oil Block Off, Set of 8
Gen V LT1/LT4 Valley Cover Gasket
GM GEN V LT1 HEAD BOLT KIT
GM Gen V LT1 Head Gasket 12659260
GM Gen V LT1 Exhaust Manifold Gaskets
GM LS7 Lifters (Full set of 16)
GM Lifter Tray LS2 and Newer 12595365
Comp Cam Phaser Limiter Kit 5456
Water Pump Gaskets
Main Seal 12634614
RTV Sealant 88864346
Crankshaft Balancer Bolt
Control Valve Solenoid 12681018
https://www.youtube.com/watch?v=8SyWCke9bFI
Parts ordered:
Water Pump Gaskets
Main Seal 12634614
#55
https://www.youtube.com/watch?v=ju1BucMwp6k
#57
#58
Can you guys give me a ballpark price on what you're paying for a cam swap? If I don't sell the car by spring I'm debating doing a N/A build. Nothing crazy maybe cam and heads. Already have headers and tune. Thanks.
#59
I priced a few places around the south east.
vengence was 4900
MTI in GA was 4000 ish
LSXperts was simalar
Bryant Brothers did mine 4213 out the door. (local to me and I know and trust there tuner.)
Car had intake and headers on it when I dropped it off.
vengence was 4900
#60
well I think this is what I am going to pull the trigger on the BTR Stage 2 NA/Blower Cam.
Will be going in a 2014, M7 Z51. So we will see.
AFE intake, Kooks long tubes Kooks off road X, factory NPP muffs.
hoping it gets its over 500rwhp, good lope at idle, and drives decent.
Once that got sorted, I loved it.
Until a valve spring broke at VIR.
TS balked at the issue, then admitted they had been having issues with the cheap Chinese springs they had been supplying.
They did the right thing and repaired/replaced the damaged/broken pieces (I think we went with PRC springs IIRC), and I've had no problem in +/- 30 track events since.
Nevertheless, I ate about $2500 in labor & towing, plus the lost track time.
Bottom line, whomever you go with, make sure you get the best valve train components you can afford, and know exactly what you are getting.
