LT1 Cam Choices
Received 1,762 Likes
You will not go wrong on this guy, He did me a set of trick flow 245 heads & cam on my c5. Car was a killer set up. Robert
Ok Money spent.
Car should be over 500rwhp when done (Somewhere in the 500-520rwhp/460-475 TQ with these mods)
Should be a good driver not to much over lap 4.5 degrees, the cam is also boost friendly incase I find a LT4 blower cheap later on. and sound like the video below.
Parts ordered:
Brian Tooley Racing Stage 2 Cam (227/242 .637/.626 @ 115+6)
Brian Tooley Racing .660" Lift Platinum Spring Kit
Brian Tooley Racing LS Chromoly Pushrods
Brian Tooley Racing Titanium Retainers
New Locks, and Valve Seals
CBI Streetcars Gen IV/V DOD Oil Block Off, Set of 8
Gen V LT1/LT4 Valley Cover Gasket
GM GEN V LT1 HEAD BOLT KIT
GM Gen V LT1 Head Gasket 12659260
GM Gen V LT1 Exhaust Manifold Gaskets
GM LS7 Lifters (Full set of 16)
GM Lifter Tray LS2 and Newer 12595365
Comp Cam Phaser Limiter Kit 5456
Water Pump Gaskets
Main Seal 12634614
RTV Sealant 88864346
Crankshaft Balancer Bolt
Control Valve Solenoid 12681018
Parts ordered:
Water Pump Gaskets
Main Seal 12634614
every part adds up, and this cam swap is not cheap! I am used to LS stuff. So sometimes you save 100-200 hear and there to make it relatively justifiable. I have a budget in mind here. if I did not I would be doing a cam swap on a ZO6 ha!
ttt
Man car sounds really good are that z06 does love the sound.Robert
Supporting Vendor
We have our own we do, I just don't make heavy ad threads on here talking about them as much as we are so busy usually. If you want something you can just grab and click into a cart the btr will most likely be fine for you.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
While I love YT. I hate when people are lazy and don't put info down. and then this being so rare/new its even harder to find anything
All my videos are tagged, and with discriptions, and info.
For example when I post a video it will say the what cam, what all mods, and what exhaust so there is not question. if you just want to hear the kooks and Npp it will pop up, if your looking for that cam it will pop up and tell you what your seeing and hearing.
Example:
2014 C7 LT1, BTR Stage 2 NA / Blower cam... Kooks Long tube headers, Kooks Off road X pipe, Factory NPP.
walleyejack (11-13-2017)
Been there and Done that. Not a big deal to me.
Mostly of what I have seen is a cam thats "custom" grind is a few degree here or there off from a shelf cam someone already makes. or maybe they play with the lobe separation. a degree lift. but basicly its going to be close to something someone makes...
I am fine with a shelf cam thats proven.
That being said, have you been at MTI for a while? I drove through the night in a black LS1 trans am back in 2001-2002 ish from alabama to have you guys tune my car vs a mail order that sucked... haha man that was a long time ago.
Billy@MTI (11-16-2017)
#33
Former Vendor
At that time I was a customer/ friend of Jayson's. Hes still going his cam magic and helps with tuning. Sorry I didn't see your post sooner.
#35
Around what kind of size is that
dont have to be exact but curious if a split like Jason used to like, and how big it is. also the separation haha sounds great.
I had Jason X1 back in 2002 in my trans am back then... those where when LS stuff was brand new! haha Drilling throttle body blades to get them to idel and stuff... haha came a long way with tuning since then
#36
Former Vendor
234/244 114
around what kind of size is that
dont have to be exact but curious if a split like jason used to like, and how big it is. Also the separation haha sounds great.
I had jason x1 back in 2002 in my trans am back then... Those where when ls stuff was brand new! Haha drilling throttle body blades to get them to idel and stuff... Haha came a long way with tuning since then
