Questions on 418 Upgrade to stock motor
I discovered a high amount of metal on my drain plugs in my last oil change. My car was the victim of failed valve springs on my head and cam package. It resulted in multiple broken inner springs. The heads were replaced with new castings and all new upgraded springs, it had several oil changes to try and flush out the metal. Unfortunately there is still metal in the motor and parts of the springs have floated to the magnets.
I have sent my oil out for analysis but I suspect internal damage has occurred in the bearings, so if I am going to go to the lengths to repair the damage I was thinking about going all the way to a stroker. I track the car so I am a big fan of NA.
How much more power is realistic with a stroker, and is it worth it? Or am I better off just freshening the motor and stay with the stock displacement?
I like my 331 Ford.
I like boost too, though.
Edit: It's going to depend on the package, but I certainly would vote for stroker. So long as you can afford it and any required supporting modifications.
I just sold a 417 LS3 C6 and its was Torque Monster stuper fun to drive
So what failed on this cam set up? where the springs past the milage to be replaced or what?
They were apparently a known weak point, the manufacturer replaced the heads with new castings, but unfortunately there may have been more damage done. They offered to freshen the motor so I am thinking of going with an upgrade. The springs had less than 12k miles on them.
Received 1,762 Likes
With this if staying N/A on the motor. But with the 416 go big radiator, D3 fan set up on the car if auto car look at the LG pan & that set up are put in a second cooler in the drivers rear fender. Robert
