Weld Wheels on their way to WEAPON-X MOTORSPORTS
WELD WHEELS AT WEAPON-X MOTORSPORTS
Since Weld is currently backed up 12+ weeks on production we have made a stocking order to shorten the wait time for client orders.
Here is the roster of inventory set for arrival this December:
Attachment 48355512Attachment 48355513
Weld S71
18x5 $587
17x10 $518
17x11 $523
15x10 $367
17x10 Bead lock $969
15x10 Bead lock $767
Attachment 48355514Attachment 48355515
Weld S76
18x5 $630
17x10 $569
15x10 $428
17x10 Bead lock $1020
15x10 Bead lock $833
Attachment 48355516Attachment 48355517
Weld S77
20x5 $638
17x10 $569
PM or email me for questions or to place your order!
Weld S71
18x5 $587
17x10 $518
17x11 $523
15x10 $367
Weld S76
18x5 $630
17x10 $569
15x10 $428
Weld S77
20x5 $638
17x10 $569
Received 1,296 Likes
2018 C7 of Year Finalist
A few questions Eddie/Ben. (Or anyone else)
1) Is 15x10 the ideal size for cars making good power? Would a 15x10.5 or 15x11 work on a Z51 or does the larger tire need a slightly skinnier wheel to fit under our fenders?
2) When are bead locks necessary? At nearly double the price, thats a big difference!
Thanks!
Thanks!
Thanks!
Thanks!
Personally I would do the beadlocks if you are going to run 15's, especially if you have a stalled converter or a big torque hit down low. I've heard of 600whp cars spinning the wheel inside of the tire, granted that could have been due to not cleaning the wheel/tire mounting wax off before setting the bead. Cars that have turbo setups or procharger's with the tq/hp hitting hard up top will most likely be fine without beadlocks, and weld can always add them after the fact if you do decide you want them later.
As long as you have the drivetrain upgrades to support it (upgraded axles/built diff/clutch if M7) the 15" drag conversion is the way to go for low speed traction. The 10" wheel width is what both the Stingray and Z06 guys use usually use with a M/T 275 X Pro radial. The width is not needed as much because the taller sidewall allows for "squat" making larger contact patch when launching. The 275 will fit the Stingray, but it is going to fill it out. IMO 15" drag conversions on the C7's is an intimidating/good look.
Thanks for the answers! I'm at 834/760 on an M7, still on stock axles and diff though. I'm currently running on 285/40R18 MT ET Street S/S radials and I know those are pretty hard on the drivetrain. One good thing is I am running a centri so the low end torque hit isn't too bad. I would think the softer tire though might be more gentle on the diff verses the DR's when they hook. Will be considering a 15" conversion closer to spring time.
Thanks!
For sure.
We go offer upgraded E-Diff's for $1600 plus your core as well. You won't break one of those. LOL just something to keep in mind for the future.
Received 1,762 Likes
ttt
Eddie will the S71 bead lock 17 inch, fit on the back of the z51 brake set up without any problems. We can go with a wide offset due to me putting the z06 wide body front & rear fenders on my car if that will help any to make it look better plus getting the rim out more..Robert
I snapped a couple pics of this beautiful ZR1 right before the rain hit us at the Wanna Go Fast 1/2 mile event in Indiana. IMO this is probably the looking ZR1 I've seen to date.
Owner: Unknown
bump
Hello, I have a 2010 Grand Sport and need a quote on some S71 beadlock rear and fronts 17"x 10 or 11 maybe even 12 ... I use 18mm spacers in the rear and 13mm spacers in the front with longer studs for full thread engagement. I currently run GM CUP wheels which are the same as the new Grand Sport wheels 19" fronts and 20" rears.
Please let me know.
Please let me know.
Ben@WeaponX (08-04-2018)
Weld S71
18x5 $587
17x10 $518
17x11 $523
15x10 $367
Weld S76
18x5 $630
17x10 $569
15x10 $428
Weld S77
20x5 $638
17x10 $569
Weld S71
18x5 $587
17x10 $518
17x11 $523
15x10 $367
Weld S76
18x5 $630
17x10 $569
15x10 $428
Weld S77
20x5 $638
17x10 $569
Do you currently have any of the s76 17x10 and 18x5 in stock?
