Stingray with inoperative windshield washer - con FUSE ion
So my wipers are fine and the reservoir is full of windshield washer fluid in my 2017 Stingray, but I can't spritz it when I pull the wiper lever. So I figure there must be a fuse for the windshield washer pump motor.
I found two fuses for headlamp washers (my car has headlamp washers, who knew?) and zero for the windshield washer pump.
Shouldn't there be a fuse for that in one of the fuse boxes? I couldn't find it.
The dealer replaced the washer fluid pump. I still have no idea if there is a fuse for it or why the car has fuses for headlamp washers. I will presume nobody else here cares, and who can blame them?
We now return you to your discussion and hand-wringing over far more impactful maintenance and modification issues.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,813 Likes
2015 C7 of the Year Finalist
I found mention of a windshield washer pump PCB Relay in the Underhood Fuse Block. The pump is controlled by the BCM
