C7 Z06 intercooler pump wire diagram
Does any body know how to wire then pump just power and ground and run the whole -when activated installing it in a grand sport with no plug for it
It has a 5 pin connector Thanks
its a 5 pin connector but only 3 pins are used anyway. i would suggest a relay to power pins 1 and 5they are linked together, pin 4 is ground
So i can splice 1 and 5 together into new pump + pole ?
and use # 4 the black one as ground ?
will replace stock pump with a better one from bosch.
tia
