2017 Grand Sport Clicking
Old 12-28-2017, 02:25 PM
Sutton720
4th Gear
Sutton720's Avatar
Default 2017 Grand Sport Clicking
I have a 2017 Grand Sport that began the infamous CLICKING at around 3,000 miles. I have had it cleaned and torqued twice and they replaced the rotors. It is still clicking loudly and it is when turning left or right at any speed. Has GM had ANY luck resolving this?
Old 12-28-2017, 04:55 PM
Ray7374
Support Corvetteforum!
Ray7374's Avatar
Mine is doing the same at 2200 miles? I have not had the cleaning/tq done. Did it help?
Old 12-28-2017, 06:57 PM
Sutton720
4th Gear
Sutton720's Avatar
It helped for about one week!! I am very upset with the situation! They have me sitting on my hands waiting for a fix from GM. It is embarrassing and annoying!
Old 12-28-2017, 06:59 PM
Ray7374
Ray7374's Avatar
Wow I’m about to take mine to the dealer for the first time for this. Is there any service bulletin that you know of I can reference
Old 12-28-2017, 08:25 PM
Marcho Polo
Marcho Polo's Avatar
Received 1,620 Likes on 739 Posts
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
I believe this one covers the issue with the rim mating surface needing to be cleaned:
#PI1498B: Clicking Noise from Front and/or Rear Wheels - (Aug 23, 2016)
I have had this done three times, and still have the noise on my 2015 Z51. They also re-torqued the axle nut, and I believe inspected splines or something.
The cleaning never did anything for my noise. When they re-torqued the axle nut, it seemed to help for a day or two, but the noise is back.
Service manager told me he got some new equipment in recently that has several microphones that they can attach and try to isolate where the noise is. He said I would need to leave the car with him for probably 10 days as they drive it and try to figure it out. I daily drive my car and I'm not too fond of leaving it there for them to drive around for 10 days. Not sure what I'm going to do next.
Old 12-28-2017, 08:29 PM
Marcho Polo
Former Moderator
by the way, here is a video demonstrating the noise on my car. It seems worse in the rear passenger area on my car. You can hear a very loud click at the beginning, and then hear it click on and off as I load and unload the wheel changing gears or letting off the gas:
ateupjoe (06-10-2018)
Old 12-28-2017, 09:03 PM
Sutton720
4th Gear
Sutton720's Avatar
Marcho Polo posted the correct reference! Very upset that we get our dream cars and then GM can’t even figure this out!
It is strange because it does it cold/hot/wet or dry.. and it seems to get louder to me but it might just be that I am irritated!
Changing the rotors did absolutely NOTHING ! So I have the serve Manager staying on top of it but still no luck!
Old 12-28-2017, 09:15 PM
Marcho Polo
Former Moderator
is the sound in my video what everyone else is hearing?
Old 12-28-2017, 09:46 PM
Sutton720
4th Gear
Sutton720's Avatar
man I can’t seem to get the video to play... but by sliding the dial it appears that you aren’t turning the wheels! Mine does it when turning the wheel left and right and rolling forward or backward at all speeds!
Old 12-28-2017, 10:04 PM
Marcho Polo
Former Moderator
It's the rear wheel in the video. I do turn in the video and the noise happens while turning or going straight.
Old 12-29-2017, 08:11 AM
Ray7374
Ray7374's Avatar
Mine is a very rhythmic ( as though it were one click per revolution) that sounds like its coming from the back.Someone brought it to my attention when I was pulling through the pits after driving on track. I noticed it when a friend was driving my car on a go kart/autocross track. I was standing on the side of the track and every time he drove around a right or left turn it sounded like a rock in the tire but louder .
Old 12-30-2017, 02:28 AM
djnice
djnice's Avatar
Totally different than what I thought everyone was complaining about. That is way better than the GS and Z06 issues where they click constantly whenever you turn.
Old 01-07-2018, 09:36 PM
Mwk
Mwk's Avatar
I got a 17 GS and my car experienced clicking noises as I turned the wheel and car. As it turned out it was alignment screws. These cars create incredible amount of torque on the alignment parts and they have to be tightened to something past 200 lbs. Most of them are not and as the car turns it will make noise.
Give it a try and I hope this helps.
By the way, most dealers or techs will not know that, I got lucky when I came in to my dealer as they just figured that out on another customers car.
djnice (01-08-2018)
Old 01-12-2018, 05:49 PM
c5racr1
c5racr1's Avatar
Had that problem, put amt camber bolts and granatelli toe rods, all gone. So i guess it’s one of the 2 causing the problem
Old 04-23-2018, 07:44 PM
onebad1lE
onebad1lE's Avatar
My car did same thing found loose bolt on control arm
Old 04-23-2018, 09:07 PM
Ray7374
Ray7374's Avatar
i did find a solution - just like the TSB talks about - I removed the wheels cleaned off the mounting surface and re installed , noise gone
Old 04-23-2018, 09:21 PM
sonny615
sonny615's Avatar
Did the rotor and wheel mating surface clean. Noise went away after I tightened the rear axle nuts. Been gone since doing that last year.
To 2017 Grand Sport Clicking
Old 04-24-2018, 09:54 AM
djnice
djnice's Avatar
I found that cleaning only worked for 1000 miles.
Old 04-24-2018, 11:45 AM
Dado5
Dado5's Avatar
My 18GS does this when turning left or right . Font wheels clicking , sounds like there are nails in tires and making clicking noise. Car has 1300 miles.
Old 04-24-2018, 01:25 PM
village idiot
village idiot's Avatar
Received 1,913 Likes on 1,053 Posts
That's probably Ackermann.
Quick Reply: 2017 Grand Sport Clicking
