What kind of RWHP should I expect from the following upgrades?
2017 corvette Z51 naturally aspirated engine package from Futural Motorsports,
R7R Motor C7 Corvette, DOD Delete, Cam Swap
GM Gen V LT1 Timing Chain Tensioner Assy
GM Performance Hydraulic Roller Lifter Kit
GM LS2, LS3, LS7 Lifter Guide Trays
GM LT4 GEN V ACTUATOR,CAMSHAFT POSITION
ARP Pro Series Head Bolt Kit for Gen V LT1 Engines
GM LS7 Valve Lash Caps
FMS Custom LT1 Camshaft - (224/236 .608"/.612" 114+7)
COMP Cams® GM L94/L99 Cam Phaser Limiter Kit
VALVE,CAMSHAFT POSITION ACTUATOR SOLENOID
FMS Chrome-Moly Hardened 5/16" Push Rods 7.425"
Brian Tooley Racing .660" Lift Platinum Spring Kit with Titanium Retainers
AMR-C72NC American Racing Headers C7 Z06 Long System 1 7/8", No Cats
MSD 8.5mm Super Conductor Spark Plug Wires, Red
FMS Custom Dyno Tuning
This is something to get me started. My car is 2 months old, so i'm just getting started. Any opinions on power. I hope it will be about another 100 to 150 hp.
Received 1,296 Likes
2018 C7 of Year Finalist
I'd expect low-mid 500's at the wheels.
A word of advice though, you are tearing into the engine quite a bit there. What are your goals for the car? If you plan on going Forced Induction at all in the future to go past 700whp, I would suggest getting pistons done at the same time while they are tearing into the motor. A bit more cost now, but will save you time and money later if you are going to get more power in the future.
