Battery was dead
Old 03-30-2018, 12:12 AM
charliechan
5th Gear
charliechan's Avatar
Default Battery was dead
I have a 2014 c7 i went away for a few weeks and i came back and the car did not want to crank over. i put a meter on it and it was about 9volts even jump starting would not work. But i was able to get in the car and i had all my dash indications but it just clicked..ok so i go and get a new battery and install that now i have no dash indications at all when i go up o the car the door just clicks like it wants to open but wont .the key fob which also has a brand new battery if i click the unlock it will click but you still cant open the door the hatch will pop open but i have to open the door by pulling the cable. at 1st the drivers window would not work but we finally got that to go back up. I read somewhere where you hit the brake pedal a few times i have tried that did not work i have no horn no headlights its like the car has completely locked up or in some kind of safe mode or something..everything was fine before i went away i am running out of things to try. Next i was just going to have it flat beded to the dealer and let them do what needs to be done it has to be something stupid that i just can"t figure out a sequel to do to get it out of this mode. any help or suggestions what i could try or do would be really appriciated...2014,20,000 mile
Thanks ahead of time
Rich
Old 03-30-2018, 01:43 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
What is the voltage reading of the new battery? Maybe you got a dead one or one with a shorted cell; unlikely but possibly.
charliechan (03-30-2018)
Old 03-30-2018, 08:44 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
Check the 300A fuse on the battery.
Double check your cable connections and I mean check them! Make sure the nuts are down tight and everything is making good firm contact especially the Positive cable. It needs to be at an absolutely correct angle or it wont make good contact with the battery.
Elmer.
Old 03-30-2018, 11:28 AM
charliechan
5th Gear
Default Dead battery
hi thanks for the help. The new battery was like 12.8 and the connections are super tight.
Old 03-30-2018, 11:37 AM
eboggs_jkvl
https://www.corvetteforum.com/forums...post1596811812
eboggs_jkvl
Check the 300A fuse too!
Old 03-30-2018, 02:10 PM
charliechan
5th Gear
Default battery change
thanks so much for this thread i had checked everything and i thought that red wire was tight but lo and behold it wasnt i tightend that up and the car fired right up....thanks again
Old 03-30-2018, 02:14 PM
charliechan
5th Gear
the car is all fixed what happened was the new battery had handles on it and i thought that red wire was tight it was resting on the handle and wasnt making contact so i nipped the handle so the wire could lay flat tighted her up and all is good....thaks for all your help and input much appriciated........
To Battery was dead
Quick Reply: Battery was dead
