How to replace the exhaust tips on C7 2018
2nd Gear
Hello guys, I'm new here and while I did search "the how to" section I couldn't find anything related to how to change the exhaust tips on C7 Grand Sport 2018. I purchased the Corsa C7 tips, but just looking at these I have no clue on what will happen to the electric exhaust tip valve ... anybody done this before?
Tips go directly into the muffler. It’s a cut and weld mod. The pic is my stock muffler with stock tips.
Received 1,762 Likes
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Those tips are not for the C7 stock mufflers. They are for the Corsa system which it's mufflers only have one exit per muffler.
Avanti (06-26-2019)
2nd Gear
thanks guys
wow I guess that might void my dealer warranty I thought it's a simple mod. anyone had issues on claiming dealership warranty on the same after cut and weld?
Received 8,927 Likes
Bill
vetten76 (06-30-2019)
What did you end up doing? The only way I can see that working is to cut the stock tips off after the valve and cut the Corsa tips off the "Y" pipe, then weld them individually onto the 4 stock pipes. I've been considering doing this as I hate the flare of the stock tip.
I want your old tips
did you end up changing your tips
i want a set of four flared out perforated inside tips to make two dual set ups
i can not find them anywhere so second hand is my only option I think
Yeah, they do look good. This C7 of mine is the first modern Vette I’ve owned that hasn’t had a Corsa exhaust. I like the sound of stock with an aftermarket X pipe. I do miss the Corsa system. Outstanding sound and quality.
I did the Corsa extreme catback and x pipe. I’m extremely happy and no drone sound. It was a little pricey with installation though.
Just as a side note covette hop has a great how to video on yu tube showing how to remove the rear bumper i did it myself lots of screws to remove but did it in around three hours total on and installed new spoiler and back on
