Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Tech/Performance
Reload this Page >
CAI - so many questions, so little time!
Old 05-02-2018, 12:02 AM
murtro
CF Senior Member
murtro's Avatar
2018 C7 of Year Finalist
Default CAI - so many questions, so little time!
Hi! I'm a complete newb when it comes to any performance bolt ons so please bear with me.
However the new GM "jake" very expensive cold air intake has peaked my interest. Doesn't affect warranty = good! Except I have a base stingray LT1... so it states 0 HP gain. If I'm gonna do this, it has to be for some reason other than $600 bling.
Questions:
- How can it have 30% better airflow but no HP gain? Has anyone done a before and after dyno test? Would a tune help?
- Instead of the new box, should I just get a green air filter and get the same result?
- Aftermarket - AFE or Vararam... any pros/cons between the two? They appear to say 17 - 20 hp gain however there seems some debate? Again is a tune required? If so - will a GM dealer perform it? Does an aftermarket CAI affect the warranty? I assume so as they seemed to make a big deal out of the GM OEM one not affecting warranty.
Much thanks for any guidance!
murtro is offline
Old 05-02-2018, 07:00 AM
RyanC7
CF Senior Member
RyanC7's Avatar
Unless you are going to tune it with other mods don't waste your money. Do a drop in reusable filter if it is dirty.
RyanC7 is offline
The Following 2 Users Say Thank You to RyanC7 For This Useful Post:
Avanti (05-06-2018), murtro (05-03-2018)
Old 05-02-2018, 10:14 AM
davepl
CF Senior Member
davepl's Avatar
Long story short:
The factory filter flows enough for the LT1 but not the LT4. Replacing the filter therefore provides a power bump for the LT4 but not much at all in the LT1. Changing the tube hasn't shown any benefit that I've ever been convinced of, any benefit seems to come from the filter.
But not for the LT1, it's already pretty optimized.
davepl is offline
The Following User Says Thank You to davepl For This Useful Post:
murtro (05-03-2018)
Old 05-02-2018, 01:04 PM
dfkruger
Junior Member
If you want to gain from gm #84152141 go with a ported throttle body and a Corsa double helix cat less mid pipe . I like the stock parts . Its spendy . If you shop you can get it for 500 bucks .
dfkruger is offline
Old 05-02-2018, 05:33 PM
spinkick
CF Senior Member
spinkick's Avatar
Get anything but the new GM intake, which is snake oil at worst and spendy for barely any gain at best. You can do way better with Verraram, Halltech or AFE.
spinkick is offline
The Following User Says Thank You to spinkick For This Useful Post:
murtro (05-03-2018)
Old 05-02-2018, 11:53 PM
JUICED1
Premium Supporting Vendor
JUICED1's Avatar
We've had plenty of happy customers with the AFE and Halltech. Next time we have a stock Stingray in the shop we should do a before and after dyno test on one of these intakes.
__________________
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your C5, C6 & C7! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, Vararam, K&N, Diablosport and much more! Call us or PM us for your Vette Forum discount, installation and tuning services!
224-63-JUICE OR [email protected]
JUICED MOTORSPORTS
1820 PRODUCTION DR
STE D
ST CHARLES, IL 60174
JUICED1 is online now
The Following User Says Thank You to JUICED1 For This Useful Post:
murtro (05-03-2018)
Old 05-03-2018, 08:07 AM
SFCTeach
CF Senior Member
I really like the Vararam. The lowest cost of all of the intakes with a long history of a solid product. I was sticking with the stock box and green filter until GM released an intake this winter and announced it would require a tune on install from GM. That is no longer the case (tune) but it shows all the talk about nothing more to gain on the intake is not the case. For the LT4 GM puts in writing 11hp. What does the other intakes gain? There are alot of dyno runs showing gains. My LT1 is tuned so I know the Vararam is only helping not hindering. CAI is a touchy subject with the owners that afraid to do any modifications to their car except spend thousands on plastic engine dressing parts
SFCTeach is offline
The Following User Says Thank You to SFCTeach For This Useful Post:
murtro (05-06-2018)
Old 05-03-2018, 08:28 PM
BlueDevilZ51
CF Senior Member
BlueDevilZ51's Avatar
https://www.corvetteforum.com/forums...with-pics.html
I installed the GM performance cold air intake, link with a few pics
BlueDevilZ51 is offline
The Following User Says Thank You to BlueDevilZ51 For This Useful Post:
murtro (05-03-2018)
Old 05-03-2018, 11:19 PM
murtro
CF Senior Member
murtro's Avatar
Yes it would be good to see the comparison.
murtro is offline
The Following User Says Thank You to murtro For This Useful Post:
Bob U (06-06-2018)
Old 05-04-2018, 11:23 AM
rb185afm
CF Senior Member
rb185afm's Avatar
What GMs filter says is, your not making more power by more flow. The LT1 is getting more than enough air for its power production. If your aftermarket filter is adding power, it’s probaly doing it by leaning out your A/F.
rb185afm is online now
Old 05-05-2018, 11:10 AM
murtro
CF Senior Member
murtro's Avatar
Originally Posted by rb185afm View Post
What GMs filter says is, your not making more power by more flow. The LT1 is getting more than enough air for its power production. If your aftermarket filter is adding power, itís probaly doing it by leaning out your A/F.
Sorry but I don't understand. All the air box can do is provide more or less air flow. The fuel source / injection and mixture is a separate system. How can any air box "lean out" the air flow other than just providing more air??
As I said, I'm a newb - so I may just be missing something simple here.
murtro is offline
Old 05-05-2018, 11:24 AM
dbaker
CF Senior Member
Support Corvetteforum!
dbaker's Avatar
Check out the BMS drop-in filter.It's for the LT1 & LT4.Do a search.
Very high quality and it's a dry media.
I was one of the beta testers.I run it on my '17.
White=BMS,Yellow=OEM,Red=K&N
\db2
dbaker is offline
The Following User Says Thank You to dbaker For This Useful Post:
murtro (05-06-2018)
Old 05-05-2018, 02:21 PM
Scudz
CF Member
Baker, whatís your results? Is this on an LT1?
Scudz is offline
Old 05-06-2018, 12:57 AM
Avanti
CF Senior Member
Avanti's Avatar
You will never tell the difference no matter what you do with the air-filter on an otherwise stock Stingray. Maybe more "sucking" noise will tell your purely subjective seat-o-the-pants it's more powerful and that might please ya.
Avanti is offline
Old 05-06-2018, 08:19 AM
dbaker
CF Senior Member
dbaker's Avatar
With the BMS(LT1),I could tell that the delivery of power was smoother and acceleration off throttle was crisper.It's a subtle diff.
Some folks will say you can't tell the diff and maybe they can't,but inside any car,I base my eval on feel.
I've been a test & setup driver for many yrs.
\db2
dbaker is offline
Old 05-06-2018, 08:33 AM
raylo
CF Senior Member
raylo's Avatar
IMO all CAIs are pretty much snake oil, especially for stock vehicles. Every dyno pull will give a slightly different result due to temps, humidity, "noise", whatever and I believe some of these sellers just cherry pick a favorable pull and advertise around that. And even if some are thoroughly and scientifically tested to eliminate variables you are talking a couple HP at best. Not worth the $$ they ask for these parts.
raylo is offline
The Following 2 Users Say Thank You to raylo For This Useful Post:
bsedwebt (05-06-2018), murtro (05-06-2018)
Old 06-06-2018, 12:45 AM
The T-man
CF Senior Member
The T-man's Avatar
ever run a Haltech ?
20115 Z06 = 46Hp
The T-man is offline
Old 06-06-2018, 09:03 AM
Black18C7
CF Senior Member
Black18C7 is offline
Old 06-06-2018, 09:05 AM
Black18C7
CF Senior Member
\db2
I'm sorry but that's all in your head.
Old 06-06-2018, 09:17 AM
cstapp99
CF Senior Member
cstapp99's Avatar
The only reason I've considered a CAI is to eliminate the goofy looking stock tube with all of the odd chambers protruding off of it. For me, the Vararam would be the choice to clean up the looks of the engine bay, but I haven't pulled the trigger on one yet.
cstapp99 is offline
Quick Reply: CAI - so many questions, so little time!
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
