Replacing steering rack without warranty, need help
Old May 3, 2018 | 12:49 AM
chaznad's Avatar
chaznad
Default Replacing steering rack without warranty, need help
Hey guys, recently my steering rack on my 14’ z51 ( no mag ride) went bad . Chevy confirmed I’d need to replace. They quoted me $3600 which is a little much. $2600 for the part , $1000 labor
i found a barely used rack with only 7000 miles from a 2014 stingray which is same year for a great deal .Will I have any issues with the replacement . Another member mentioned the module in the rack is programmed at the factory to your vin which caused his service light to stay on
Any ways of making this a clean install . Does install need a GM dealership or is this something most mechanics can do
Old May 3, 2018 | 09:07 AM
Clifftrail's Avatar
Clifftrail
Just curious but what went bad with it?
Old May 3, 2018 | 09:10 AM
chaznad's Avatar
chaznad
The dash lit up " SERVICE POWER STEERING , DRIVE SAFE " Took it to the dealership , they said it needs to be replaced.
Old May 3, 2018 | 09:15 AM
Clifftrail's Avatar
Clifftrail
Did it drive/feel different or just the CEL. Is it possible something got affected with the wire harness or a loose connection? That's a mighty expensive part/fix. Wish u luck with getting it resolved.
Old May 3, 2018 | 09:18 AM
chaznad's Avatar
chaznad
No the steering wheel got real tight. Big difference,10x stiffer then track mode , I can still drive it but requires muscle to steer
Old May 7, 2018 | 11:26 AM
ersatz928's Avatar
ersatz928
Remove the old rack and install the replacement yourself. If the power rack does not work, you need the dealer to reprogram the control module (part of the rack) to work with your VIN, that is called a "SPS" (Service Programming System), and probably requires 1/2 an hour of dealer labor. Then you can also have them do a front-end alignment, to set your toe angle.
Old May 7, 2018 | 11:54 AM
chaznad's Avatar
chaznad
Purchased a replacement rack with only 4000 miles for my 2014, should arrive today. Calling around to get quotes for install since Chevy wants $1000 for the install w/ alignment..
I called a local shop that said it was able to program the rack because it has GM programming equipment . Do you guys know if this is possible or can only GM do this ??
I would love to install myself but not sure I'm capable of this , especially with no write up on how to pull. Based on the quotes I'm getting , it must be an 7-8 hour deal
Old May 7, 2018 | 01:02 PM
ls2 67gto's Avatar
ls2 67gto
Looking at the service manual you have to drop the front cradle before you can remove the rack so I believe the 7-8 hours. Looks like a big job for sure.
Old May 8, 2018 | 12:21 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I can do the rack in like 3 hours on the C7. Less if I had a lift. If you are mechanically inclined, its not that bad.
I’ve pulled mine twice and never dropped the cradle. That may be what the manual says but it definitely is NOT required.
Old May 10, 2018 | 03:28 PM
chaznad's Avatar
chaznad
Well too late , I just had GM replace it , $1000 later. Rides perfect again but still throws a code. The code doesnt appear on the dash just with the scanner when diagnosing . Not sure what thats all about but im happy again
To Replacing steering rack without warranty, need help
