Z06 Spark plugs & wires
Corvette Z owners, thus I am new this vehicle forum, I am learning at a high rate and very thankful of the technical support that I have received. I have a question that I ponder and I am in hopes that someone may be able to provide me guidance and or direction. I am in search of the best and or better than OEM spark plugs and spark plug wires for my "15 Z06. I noticed my vehicles idle that sounded as though it had a skip. The idle is similar to the idle of my LS3, that had a slight miss at idle, which this turned out to be a plug wire arching which resulted in foulling out that particular cylinders plug. Any assistance would be greatly appreciated.
V/R
V/R
Your going to get many opinions so I'll just go ahead and give mine, lol.
I have a 2016 Z A8 and recently went with black MSD 8.5mm spark plug wires and NGK Tr7 IX spark plugs gapped at .028. I gapped it close and went with a colder plug because I have a cai with hi-flow filter and long tube headers. The car seems to like it. Sometimes the car idles perfectly smooth and other times it acts as if it stumbles a tad bit but that's the nature of the beast when you have mods.
I also went with this setup because I have ran similar setups in all of my other vettes and f-body's. Good luck...
Replace spark plugs
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Before you start replacing parts, I would recommend you log (or watch) for misfires. If you have a plug wire issue you will see the misfire count, particularly on a single cylinder. There are various software/hardware solutions that can provide this information to you.
Avanti (02-20-2019)
Received 8,928 Likes
I had one car a number of years ago that indicated plug replacement at 30K miles which at the time was a huge improvement over the previous 12K mile replacement interval. I let it go to about 37K before replacing them. I was surprised when I got the plugs out as the center electrode in all 6 plugs was worn down to nothing. I didn't understand how the car had been running that long with worn out plugs.
Bill
Probably time to start thinking about it. I would also replace the plug wires since you may find you damage them getting them off the plugs.
Bill
Bill
Bill
Received 2,379 Likes
I like to run Brisk Silver plugs one heat range colder than stock.
