Detailed review of a Mamo Motorsports ported TB
Thank you. It makes sense. In my case I would be interested to have mine ported, why waste a good TB by not using it? I don't intend to go back to stock. I had a ported TB in my previous car (2012 Camaro SS) and it did made a difference, enough to feel the stock C7 has a throttle tip in lag compared to the Camaro, the Camaro throttle felt much more responsive. If the throttle is pushed enough on the C7 it returns lots of power compared to the Camaro, but the first 10-30% throttle tip in on the C7 is sooo off putting for me to the point I miss my Camaro sometimes... GM probably had it programmed like this for safety, thinking not everybody can handle all the LT1/LT4 power.
Supporting Vendor
Also in the event you have an issue with one of my ported units I could easily exchange it if it were new.....not so easily if it was/is used.
Its simply nice to fall back on the fact you still own the stock TB and purchasing a new ported TB outright for only a few more dollars makes it a faster much smoother transaction for all.
If you have an interest shoot me an email or PM and we can go forward from there. It truly is a fantastic upgrade and worth every penny of the outright purchase I assure you.
Don't forget I offer a 30 day trial period for you to decide for yourself!
Cheers,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
This was my first mod on my 17 Z06. Followed by the MGW. Very satisfied with both.
These cars are alot more finicky (versus your previous 5th Gen Camaro)....having the stock TB to fall back on is a perk and you don't save alot of money either porting your stocker ($270 shipped plus you pay $20 ish to ship it to me),
Cheers,
Tony
Cheers,
Tony
Wait, what is your reasoning on not considering a ported throttle body?
Honestly you need to do more homework.....the more you read the more you will want to own one.
Regarding auto vs manual and the gains experienced, I have gone over this numerous times in various threads but it's worth repeating.....in a nutshell.....ALL THE UPSIDES ARE THE SAME.
Your engine has no clue what transmission is bolted behind it.....all the perks of my ported TB are exactly the same including the 12- 15 RWTQ and 12-15 RWHP it adds as well.....the increase in throttle response, the removal of the lag off idle (which is simply masked more with the auto because there is no clutch pulling the engine down and less fancy foot work....LOL)....the large improvement in tip in throttle and the more linear intuitive power delivery.....its ALL there. The manual trans cars and the autos all reap the same benefits of this upgrade.
In fact I have helped many guys that have an A8 (who didnt realize they even had an issue) that simply wanted to try my product because of all the good reviews (knowing I offer a 30 day performance guarantee as well so no risk). Many of them took the time to email me back and let me know that now the car feels especially awesome with this upgrade and they didnt realize how bad it was until they felt how right it could be with the modified TB I offer.....a welcomed surprise on the upside for most.
While the manual trans guys are thrilled it helps remove/eliminate an issue that is more obvious (specifically the off idle lag), the A8 guys have been just as happy and as I mentioned more surprised mostly not realizing what they have been missing all along.
I encourage all of you running a stock LT1 or LT4 TB to try one of my modified units....its plug and play....no tune required....if your not totally stoked about the money you spent with me you have 30 days to return it for a full refund. Not too many opportunities in this hobby that offer you that type situation.....take advantage of it while you can. Also, clearly your not taking a flyer here....there must be a few hundred posts with extremely satisfied customers running my products. If your new to this hobby or the GM platform I recommend you Google my name if your unfamiliar with my background. I have been designing high performance cylinder heads, intake manifolds, and TB's for two decades and I basically specialize in the art of airflow. I should add that while I have designed cylinder heads and various airflow related products for alot of different brands over the years (even sport bikes), Im a "bowtie man" at heart and GM products make up 90% of the gear I specialize in.
Cheers,
Tony
Cheers,
Tony
Supporting Vendor
I received and installed mine. Very, very happy!
Tony, you don't have to worry about me returning it after 30 days LOL!!! And I only drove it for less than 100 miles with Mamo TB on it. I cant' wait to drive it more now.
Car is predictable now, just like I expected and how I was used to drive my former Gen5 Camaro SS (truth to be told, I had a ported TB and CAI on the SS ). No more weird throttle reaction, the throttle is linear now, a REAL pleasure to drive!
Thank you Tony!!!
Thank you Tony!!!
Thank you Tony!!!
Thank you Tony!!!
Supporting Vendor
Guys,
Thought I would add to this thread another in depth well written review
Hope you guys are enjoying the long Holiday weekend!
Cheers,
Tony
Cheers,
Tony
I installed a Tony Mamo ported TB last Monday and have put about 120 miles on my car since. No codes or issues on start up after install, car ran normally. Car is still completely stock except for a Green Filter, 2018 ZL1 1LE.
Both runs started at sea level and ended at a little over 10,000 ft. Between 4000 ft. to the top, driving was "spirited". Air temps were between mid 80s and 50, weather conditions (dry/sunny) between both runs were nearly identical. PTM in sport/competitive mode (TC off with access to full power at all times, StabiliTrak on) for 100m before and after install for continuity. There were no issues with the rapid altitude changes.
I attached a cool drone photo of part of the route.https://www.camaro6.com/forums/images/attach/jpg.gif
My immediate reaction was that the throttle response was noticeably smoother from a stop. I thought that it might take some time for the ECM/ECU to adjust, from a dead stop it was instantaneous. Over the next 100 miles as the computer adjusted to the cleaned up airflow, I've noticed that the throttle response has become increasingly more smooth throughout the rev range (low to mid, mid to WOT, low to WOT). Blip to downshift is way more predictable manually and when using auto rev match. Throttle response is much more linear, it's especially noticeable during acceleration on corner exit.
IMHO this is definitely a very reasonably priced mod that yields a noticeable performance gain. My butt dyno tells me there is likely some more power there, regardless; the throttle response is worth the full price of admission.
I'm truly impressed with the performance gains. I also appreciate that Tony has taken the time to respond to and answer all of my questions. Great customer service.
For reference, I have not been compensated in any way for posting my impressions. Just my honest opinion.
#33
Wow - how did the Chevy engineers get this one so wrong?
I am in the Vitesse camp. This car’s throttle is drive by wire - computer. My experience with Vitesse and BMS filter has been excellent - never a code and over $200 saved.
Look who started the thread. I guess sales have softened.
#34
#35
I run all 3: TM TB, Vitesse and filter. Love it!.
#36
Supporting Vendor
You dont have to be an expert in airflow to see just how bad it is with a vertical wall around the entire perimeter disrupting airflow at both low throttle angles and WOT (and all through the curve for that matter).
The reality here is this TB was never designed with a Corvette in mind.....it was an inexpensive shelf item installed on trucks and other vehicles making half the power. It was never a performance TB from its inception and in out of the box trim it's the worst of any factory TB I have ever ported....GM or otherwise. Compared to the new TB designed for the LT5 ZR1 application its night and day. That TB was designed with a performance engine in mind but can still flow more with the proper porting techniques (its just MUCH better in out of the box trim with no huge design flaws as glaring as the LT1/LT4 units). I mention that to make a point as the LT5 was designed specifically for a Corvette high powered application unlike the TB in question here.
When Im done reshaping the housing bore it makes a huge difference in the amount of airflow in the lower throttle angles and increases total flow by a substantial 17% (1000 CFM versus 850 CFM). The big gain in airflow is what increases the power from the engine at WOT.....no different than installing a higher flowing carb on a hungry performance engine back in the day
A ported TB upgrade is a true performance mod that increases the engines V/E (volumetric efficiency) , increases throttle response.....reduces the lag off idle and makes the throttle input much more linear in nature.
You should try one.....I offer a money back guarantee for 30 days if you don't feel it was worth every penny. At the very least it will give you the opportunity to see just how poorly designed the LT1/LT4 TB's actually are hopefully giving you some pause before defending the GM engineers again. The fact that GM gave this TB the nod on your Vette was a very poor decision and it was all about the "bean counting" and nothing related to performance or the enjoyment of your car in any way or form I assure you.
Try one of my ported TB's.....you will thank me as many others already have
-Tony
Vegas1500 (09-14-2018)
#39
Supporting Vendor
They just sound the same on paper (a ported TB, a ported cylinder head, a ported intake manifold, etc.)
This is a good thread (more technical in nature) to better understand how there can be a difference
https://www.corvetteforum.com/forums...ts-inside.html
Try one of mine and decide for yourself....I offer you a 30 day performance guarantee. Dont feel it was worth an improvement send it back but I have a hunch you will want to keep it
Its one of the few "anomalies" in the aftermarket performance industry where for little dollars spent you actually experience significant real world gains in your vehicle and the best thing with this mod is you don't have to go WOT to experience the upsides. Just driving the car normally the improvements from this upgrade make themselves readily apparent. Its really how the car should have came from the factory
-Tony
#40
No issues with running the ported TB and Vitesse together? LT1 or LT4? What setting do you run the Vitesse on?
