Is a tune required?just installed Kooks headers and ultra high flow cats...
I just had a set of Kooks 1 7/8 headers with the ultra high flow green cats installed on my 17 grand sport. I bought this set up mainly for the sound and not so much for performance just because I know once its tuned I can guarantee my warranty is out the window... I know some will debate the use of headers alone would void warranty.
I know without a tune im Not maximizing performance but my question is could I be causing damage to the engine by not tuning??? I was under the impression the use of kooks green cats did not require a tune. The car is completely stock with NPP. When I picked up ther car from installer the CEL was on and I was disappointed because I read that you would not get a CEL with the green cats. I drove 20 miles home and noticed a loss in performance and not really much of a increase in sound aside from WOT. When I got home I unhooked the battery to try and reset the CEL. The next morning hooked battery back up and started with no CEL. I've since drove it 4 times for a total of 25 miles and the CEL has not come back.... am I safe to c ontinue driving it as long as there is no Engine light without a tune or do I risk causing possible damage???
Received 1,762 Likes
ttt
I have a 2014 A6 I did a LT headers, 3 inch AKRAPOVIC X pipe with MPP mufflers also. ported intake & T.B. with no tune on the car. I can tell you the c7 runs rich from the factor, I checked my plugs before doing these MODS Plus I only did one mods at a time just to be able to tell IF something did go wrong what it was that did it. I did all of above now the car is running leaner to the point of the plugs looking much better now like a tan color & before they were black & you could wipe off black wet like gas from them. But with all of this car never ran much better without a tune on it that is not worth it if you dont get the car tuned.
Pull your drivers side & check your plugs. Car now has a A/A TI blower on the car & has been tuned now. Robert
Did you ever throw a code when running those mods? Good to know these c7 run a factory rich fine since I'm assuming the LTH will learn it out some. I will check my plugs as you mentioned. I do plan on doing an AA supercharger down the road, but not for awhile.
spinkick (07-30-2018)
Bmwmike (08-04-2018)
mike, I have a trinity t1000 that I used my last car. But it doesn't appear it is compatible with my 2017 grand sport. What are your recommendations? Would one of the canned tunes help achieve higher HP with let's say the perf 93 tune with LTH?
Supporting Vendor
Canned tune will not be ideal, you really want to look into a custom tune to get the most of an expensive investment like longtubes.
As for warranty, no worries with the Trinity. You certainly aren't gonna hide them headers though
OP here it will run fine but does need a tune for you to get the added HP from the add on's. Also for these add on's it really did lean my 2014 out to the point it cleaned off the plug tips from black really rich to a nice lean color that they looked good to me like they should be on a plug.
I did get a box from mike here on my car until I did a A/A blower set up on the car. I then got a tuner to remote tune the car for me with HP tuners...
It may throw any codes related to bank 1, sensor 2 and bank 2, sensor 2. I turn off reporting of 21 codes when I tune for longtubes. I also command the throttle blade open 100% at 100% pedal position at any rpm. The factory is around 22% at idle and not ramping up to 100% until about 3500rpm (all c7 and c7z), and everyone here seems to think ported throttle bodies get rid of it... I get a chuckle out of it every time I see a throttle body thread. I post facts about the issue, and I am dismissed by all of the non-tuners. People who know and tune gen 5 GM torque- based controllers know the truth. Fact is, a tune by itself will gain more than longtubes and no tune.
John
John
John
John
