Halltech or AFE
Tri3 , are you asking me ???
if so just follow the steps I outlined ..
#1 stock
#2 93 tune
#3 Diablo CAI tune and VARARAM
Same track temps in the high 80's , DA bad ,and marginal track grip
I recently installed a Borla Catless X pipe and I have a ported throttle body and a ported intake manifold I have to install .
Dave
#1 stock
#2 93 tune
Dave
Thoughts on the 93 tune , its conservative , was there a difference , yes but it was not all really HP as the claimed 20 HP I am sure could hardly be felt . What you can feel is the improved drivability of the car . The Diablo tunes reduces or turn off TQ management which in itself is a HP gain . You also have the ability to adjust your gas pedal response , I adjusted mine to +20 % which eliminated the lag we all talk about
There are many other parameters that the tune changes . Once your fuel trims stabilize you will find out , while its not earth shattering, you are faster than the other guy .....
Now when you do the Diablo Lew custom ECM and TCM tune , now you will feel a real difference as much more is changed ......
Folks say dont waste your time with a handheld , remember what you tune the car with does not matter hand held using CMR , HP tuners or EFI live . A handheld is just the device to upload the tune . All the same parameters can be changed with CMR as you can with HP tuners or EFI
Up until the point where you are doing heads cam or a blower a remote tune done with a Handheld or other device by any of the name guys out there is just like a street tune done locally , make the changes , log the changes , make more changes , upload again . Rinse and repeat as many times as you like until satisfied. Am I leaving a few HP on the table , I am sure I am but knowing that I am not dependant on some guy who might go bankrupt in 2 years or who might have locked my PCM is worth it to me
And I also have the ability to return my car to stock at any time and upload my original tune back into the PCM ...
Dave
Dave,
Thank you for your insights and taking the time to give me something to go on, appreciated much! I too would stay a bit conservative not wanting to melt a piston, etc. I'm not all that technical at data logging and then making assumptions as to making adjustments. Maybe that will come with some 'easy' tinkering...
Side barring a bit: I have driven in your neighborhood twice on Atlanta Motorsport Park, once in my APR tuned Golf R and out of 30 cars at that particular event, my buddy(co driving) finished 2nd out of 30 cars, .2 (point.2 tenths) behind a new NSX serial no. 0000 driven by a car magazine editor.(not sure he is all that good, but likely good up to a point). Took it today to get the latest stage 2 update, APR claims zero to 60 in 3.2, it is a hoot:-) On stage 1 tune I took it to a drag strip just to check it out and first pass on a cool day, it did 12.005 at 115.xxx :-) 2nd time at Atlanta I was in my 2014 Z51, over heated the brakes. That track is a blast!!!
OK, back to tuning and the Vararam. Are you satisfied with the intake?
thank you again
Bruce
thank you again
Bruce
I love AMP , my kids bought me a package and I ran my C6 there with 3 of my friends who also bought the package , was an awesome day . We are lucky to have 3 road courses and s 1/4 mile strip all real close .
The Vararam fits great and was easy to install , there is no need to unplug the MAF sensor during installation so I did not because there were reports of te ECM popping a code
During my first high speed run down the 1/4 mile I did get a check engine light but I reset the light and it has not come back on again , I have since run the car a multitude of times and with the tune it does not look to be lean at all as the fuel trims look good
The best part about the Vararam is , it is unsilenced so when you jump on the car hard it sounds like my old BIG BLOCK Chevelle with the 780 CFM Holley ....it sounds awesome
Dave
Dave
Bruce0293 (11-29-2018)
E-Ray, 3LZ, ZER, LIFT
Received 9,616 Likes
This is my experiance with an aFe installed on my 2014 Z51, removed when sold, oiled cotton filter cleaned and reoiled and installed on my Grand Sport. Great “sucking sound” at WOT!
This is an 11 page pic/text PDF of the installs. There was an error in the original install info that is covered after a call to aFe. Great folks. Believe it has since been corrected but with reviewing as the rubber grommet on the OEM filter housing is reversed on the aFe when installed:
http://netwelding.com/Cold_Air_Intake.pdf
They sell both oiled cotton and paper filter. These are both larger than the OEM requiring a larger housing and different air tube. The GM system appears to hold the same size OEM filter. A forum poster who bought their more restrictive paper filter did a before and after dyno comparison and got 10 hp. aFe had published a dyno comparison when I got mine showing 17 hp gain and torque increases from ~2500 rpm with their oiled cotton filter. Recently looked at their website and they have 2 more test comparisons showing 15 and 18hp gains with oiled cotton. They publish none with their more restrictive paper filter.
Did they pick the best dyno runs? Probably, but do give the test conditions etc. In my discussions with their techs they have been very helpful and knowledgable. Made suggestion and supplied a small threaded plug needed to block one hose barb on the 2014 system when putting in on the Grand Sport.
I’m lucky as have a ~3/4 mile long road near my home between farm fields with no homes and often no other traffic. Frequently hit close to redline in 2nd and 3rd with the Grand Sport when I turn the corner onto that stretch. The cotton and corn don’t care about the noise or how fast I’m going!
#34
Dave
Dave
Bruce
#35
I love the performance of the car. I would like to see some luxury options on a car that expensive.
such as rain-sensing wipers
Standard level of safety issues options like blind spot warning
collision avoidance should be standard
#36
Now that more people have the Vararam CAI, as its been out for a bit now. How are the results vs the top 2 Afe & Halltech? either dyno or real world 1/4 results etc.? I don't mind spending more if Afe or Halltech truly gain more results on the street. I have a Tony Mamo PTB ready to be installed and can NOT decide on an intake. Most likely run that for a bit and if its lean or not running well either go custom tune and add xpipe with mid-lengths or longtubes but thats another decision I need to make LOL. Thanks!
