2 Step install clutch switch connection
I purchased the MSD 87331 2Step unit and got it pretty much installed. The only thing now is to hook it to the clutch switch(I believe). has anyone installed this to the clutch switch?
I'm curious how you get down under the the dash to even get to the clutch switch. Also I need to to is get the cable from the box(engine bay) inside the cab toward the clutch pedal. any suggestions with that? So far the install on rails and mounting have been super easy.
Hope someone has some insight!!
Thanks,
Rich
Thanks,
Rich
