Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 Tech/Performance
Reload this Page >
Ported Throttle Body vs Viteese/Sprint Booster
Old 11-08-2018, 05:56 PM
justplainjim
CF Senior Member
justplainjim's Avatar
Default Ported Throttle Body vs Viteese/Sprint Booster
Do both products have the same function, improving throttle response? Does one perform better than the other? Will they void warranty?
Thanks..
justplainjim is offline
Old 11-08-2018, 06:08 PM
ahero4eternity
CF Senior Member
I have both - Mamo ported TB and Sprint Booster.
A ported TB is unlikely to cause any harm to your Vette. Most PTBs are modified OEM parts, and I'd be very surprised if a GM mechanic even realized that the TB was modified if an issue arose. However, if you do have an issue and are worried about voided warranty, swapping back to the OEM unit takes about 10 minutes. The dealer would never know it was installed.
A Vitesse or Sprint Booster are plug and play units that simply amplify a signal. They are not re-writing anything or causing any permanent changes. Again, this is a fast install/uninstall (5 mins tops). Once unplugged, the dealer would ever know one was installed.
That said, I installed the PTB first. It made a difference, but I wanted more. And hence the addition of the Spring Booster. I chose the more expensive Sprint Booster because it's smaller, self-calibrating, and has more adjustment (plus valet mode and pedal lock).
If I had to pick one over the other (Vitesse/Sprint Booster or ported throttle body), I'd now choose the Vitesse/Sprint Booster. I was initially planning to stick with just the PTB as I don't like messing with electronics, but the PTB just wasn't enough. Others will disagree. I did not notice the night/day difference with the PTB alone. The Sprint Booster was, on the other hand, night/day. I think the reason some people shy away from Vitesse/Sprint Booster is reliability, but I haven't had any issues *knock on wood.*
ahero4eternity is offline
Old 11-09-2018, 08:15 AM
justplainjim
CF Senior Member
Thanks for the great reply. I never thought about using both products together..
Old 11-09-2018, 12:33 PM
JUICED1
Premium Supporting Vendor
JUICED1's Avatar
A good tune will do everything the booster does and more. It's just some basic tables that need to be adjusted and the pedal feels so much better. A ported throttle body and/or an after market intake will help out a bit to but the biggest issue is in the throttle lag from crap GM tuning.
JUICED1 is online now
The Following User Says Thank You to JUICED1 For This Useful Post:
justplainjim (11-09-2018)
Old 11-09-2018, 05:51 PM
justplainjim
CF Senior Member
Juiced, would any reputable speed shop know what tables to tune out the throttle lag?
Old 11-16-2018, 09:12 AM
subieworx
CF Senior Member
These are two entirely different products that in no way overlap.
The ported throttle body increases airflow through the engine and as a result makes more power.
The throttle controller adjusts the actual throttle body opening for a given pedal input.
subieworx is offline
The Following User Says Thank You to subieworx For This Useful Post:
justplainjim (11-16-2018)
Old 11-17-2018, 05:18 PM
ahero4eternity
CF Senior Member
Never heard of a ported throttle body making more power. Certainly not what I experienced.
Old 11-17-2018, 06:55 PM
Ronstar
CF Senior Member
then why would you port it?
Ronstar is offline
Old 11-17-2018, 09:32 PM
Dcasole
CF Senior Member
Dcasole's Avatar
better response.....
and for those that say you can do the same thing in the tune as a Vitesse or a Sprint booster ... sure you can but it's not adjustable .
I adjust my Vitesse all the time at the track .... good grip and I crank it to SP9 , bad prep then I crank it back to SP0 to SP2 . I am consistant as hell with my 60 ft times on stock runflats no matter what the track condition is
Dave
Dcasole is offline
Old 11-17-2018, 11:06 PM
MlwYlw
CF Senior Member
MlwYlw's Avatar
Agree with above. Best $179 is Vitesse followed by the Range AFM disabler for the A8. Two must have mods.
MlwYlw is offline
Old 11-18-2018, 05:37 PM
AZGASSER
CF Senior Member
AZGASSER's Avatar
I have a Katech ported TB for sale. Swapped out for a ZR1 95mm TB. About 18 months of use. PM for details.
AZGASSER is offline
Quick Reply: Ported Throttle Body vs Viteese/Sprint Booster
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
