Holy hiccups Batman. $3,000 for fuel sending unit replace
I just read in general discussion the cost for replacing fuel sending unit is $ 3000. I’m hoping we can have a DIY guide to perform this. I would try to do this repair myself if and when I need it.
General discussion, 2014 C7 multiple issues need assistance
FYREANT (11-16-2018)
It's a PITA. Just installed a Fore Innovations dual pump kit in a customer's C6. Between parts and labor it was 5k. C5+ fuel tank design is some of the dumbest crap I have seen in the automotive world.
Moderator
Then people don’t listen when a credible source says to store the vehicle with 1/4 tank. Live and learn.
Cruise-In IV Veteran
Also an A8 is worse than M7. Still have to drop the torque tube down with rear tranny to get the tank cross tube out to drop the tank. I went through all that before I just decided to do a custom low side using a custom pickup tube. Just too much work for me to get a damn fuel pump in. Now if I was changing my clutch then yeah makes more sense.
Received 8,928 Likes
Bill
C5-VERT (11-17-2018)
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
It's expensive 'cause you gotta drop almost the whole power train to get access (torque tube, tranny, differential and complete rear end cradle......
So if there's a permanent fix by using an aftermarket fuel pump system, we'll be able to pay just once for a fix. Let's hope GM, helps us out on this one, hopefully before ours go out of warranty.
