MTI’s new low side supplementary fuel system for the C7 Corvette solves the low side pressure drop issue with modified direct injected C7’s and those running E85 fuel. Fits all C7 model Corvettes (Stingray, Grand Sport and Z06). Easy installation with step by step instructions including everything you need to install this kit on your C7 Corvette. Includes high output OEM quality Walbro fuel pump, black braided lines cut to length with all fittings already attached. Custom wiring harness with plug and play weather pack connectors for ease of installation. The included MTI fuel pump control module automatically activates the fuel pump under engine load and has an integrated test button feature to check fuel pump function. The MTI fuel system kit also includes at no extra charge, a drill bit and tap for the fuel tank feed fitting, E85 compatible thread sealant as well as fuel line disconnect tool to help properly drain the fuel tank and install the fuel pump at the rear of the car. For those looking for an easy to install package to improve their low side fuel system output, the MTI C7 fuel system is the solution.
The Price is $1000 plus shipping. Call the shop or buy threw MTI.store
Thanks,
Billy
To supplement the high pressure fuel system with another pump T'd into the fuel line. Very common thing to do when reaching the 800-900 rwhp mark and needing more fuel.
I have a C7 Stingray with an Edelbrock E force making over 550whp on 93. If I wanted to go E85 would this kit be all I need to adapt my stock fuel system for fueling E85?
You will need LT4 Hp Pump and injectors. At 550 your tapped on fuel.
Thanks,
Billy
