C7 magnetic ride eliminators (coil-over conversion)
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I did a quick search but did not come up with many results. What are most using for mag-ride eliminators when converting to Coil-overs? I see the KW EDC Delete unit, which may be the best option I can find, just curious of any first-hand experience.
https://www.kwsuspensions.com/produc...-68510357.html
Premium Supporting Vendor
https://www.lgmotorsports.com/corvet...imulators.html
fleming23 (12-17-2018)
I've switched to Penske 8300 remotes with LG shock sims and have had no problems (Got one track day with the new setup and ran into no issues). I'm also running the LG G2 swaybars and toe link kit.
The LG sims work fine - however I occasionally still get the "Service suspension" error on the dash which I dismiss. To be clear - The error does not pop me out of PTM modes or interfere with TC/AH at all.
Other than that the switchover to coilovers along with the LG stuff has been transformational. The car now feels planted like it never did before.
I did a ton of research on the DSC controller and after talking to some locals who've also had DSC and then removed it I decided against it for heavy track usage - too many errors while on the track causing spinouts etc. I concluded the DSC controller isn't something I want to rely on while I'm heavily loaded into a turn and have it go out on my right in the middle of the turn.
Do you know, or remember, the spring rates on your car? Just curious for comparison for when my car is spec'd. Also, do you find yourself making many adjustments to the reservoirs for handling adjustments?
I would LOVE to go coilovers but these simulators seem real sketchy.
First I've heard of a service suspension message with our sims. Either way, I don't know that I would go so far as to say it's sketchy, given that it doesn't kick him out of driving modes or hinder performance in any way.
I just mean they are a work around that doesn't seem 100% to me.
I loved my LG coilovers on my c6 but this whole mag rag simulator situation on the c7 just has always prevented me from taking the plunge again.
let me be clear. LG is awesome and their sims work ... for some reason every 30 minutes or so I get a Service Suspension error that I dismiss using the OK button on the steering wheel. The error does not do anything negative at all - there is no interference with PTM. If I had the sims completely unplugged then I wouldn't be able to go into PTM - so yes the sims are essential and vital for coilovers.
I already have errors for no TPMS and airbag so I give zero fks about one more error lol as long as it doesn't interfere with PTM.
My spring rates are 750 front, 650 rear
switching over to coilovers is well worth it (even if it pops an occasional error) as the transverse leaf spring setup on the corvettes is something I personally detest!
It's not very harsh on the street. Feels roughly equivalent to sport mode when I had my mag shocks but with less pogoing - more stable.
Since I have remote reservoirs I can dial down comp/rebound if needed easily.
C7 of Year Winner (track prepared) 2019
I have a service suspension warning every time I start the car.
I have to clear the Airbag message, TPMS message, suspension message, and if it's the first time startup after flipping the killswitch on I'll have a rear axle message.
Finally a positive reason I bought a 1LT with no magride.
Hm I'll check with the company that makes them for us.
I have the bc coilovers with the AFE delete kit.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,813 Likes
2015 C7 of the Year Finalist
Sounds like you have broken some circuit in your suspension and might need a tune to tell the ECM to ignore the suspension messages.
Elmer
Elmer
hey guys, just wana get in on this topic if I may. I also switched to coilovers with the mag delete. I also get the “service suspension “ error. I press ok and it goes away. But lately I’ve noticed it interferes with the speed limit. I’ve noticed that everytime which is not common when I get the error notification on the dash. It doesn’t allow me to go pass 85mph. I’m not sure how to stop that. It’s weird.
So with the help of @Dane@LGmotorsports he put me in contact with the right people to trouble shoot this.
I'm in the middle of testing with them right now, but as my car isn't street-able I have to wait for a track test day this weekend to confirm the results.
So far it's pretty promising though. I'll be testing the car on Sunday to confirm. if it works, ill let you know.
The following 2 users liked this post by lobsterroboto:
badhabit_wb (10-08-2019),
Dane@LGmotorsports (10-09-2019)
