-AN fittings on dry sump tank
Does anybody know of a way to add -AN fittings to the factory tank or know of an aftermarket tank that has them that will fit a c7 z06? I want to leave the factory oil cooler/heater on the car for street use but add an air to oil cooler and use an adapter on the right side of the motor, go through a thermostat, through the cooler and then back to the dry sump tank. Thanks for any help or ideas.
I've also thought about an oil filter relocation kit and using that, with a thermostatically controlled valve, to add an oil cooler. Any suggestions on either route would be appreciated.
Can't help you on the -AN tank but I did use one of these on my 350z track car. Only issue I had was the o-ring that came on the kit wasn't thick enough and was creating an oil leak. This was easily fixed by using an o-ring off of an old oil filter.
badhabit_wb (12-20-2018)
Thanks. That's kind of what I'm talking about. I don't think there's enough room to drop the filter any lower so I would have to relocate that. I'm either going to do that tap in on the tank side. Any ideas help.
The following 2 users liked this post by 3X2:
Avanti (12-26-2018),
I haven't looked at this particular tank, but I can tell you having welded on sheet metal oil tanks in the past that its really hard to weld tanks that have had oil in them. The problem is the walls are relatively thin, and when you get weld penetration to the inside of the tank, the oil residue contaminates the weld producing pinhole leaks. If it has fittings (preferably steel) that can be removed and welded to that is preferable by far. I would hope that it just uses pipe fittings that can be removed and swapped out for the required AN hose size.
