Need info on headers before buying-C7
For those really in the know, I have some questions about adding headers to my current set up. 2107 Grand Sport currently with Corsa x pipe, factory cats, and B & B Fusion cat back NPP exhaust. Im possibly wanting to add headers to this set up. 1.What headers will fit the factory cats and Corsa x pipe? What size, shorty, mid length or? 2.What gains if any without a tune (not interested in a tune) 3. What brand ie Kooks or? 4. Will adding the headers cause a CEL? Thanks for any expert replies!
ARH catted mid length will bolt up to your corsa x pipe. They will replace the primary cats with hi flows. Advertised not to throw any codes. Without a tune I really don't know how much power you'll add. No longtubes if you don't want to tune, or have to take that Corsa X pipe off. There is a thread on numbers for ARH mids power gains with and without a tune. Do a search. For the record I have TSP 1 7/8 headers tuned.
Received 4,689 Likes
Don't spend your money on any exhaust upgrades unless you are going with long tubes. It is not worth the money and labor to go with "shorties". If you go with the long tubes, you will need to buy the header manufacturers X pipe also, at least with Kooks you do
c6txvette (01-24-2020)
Well said and thanks for the reply. Since I posted this my local Corvette shop pretty much said the same thing. He quoted Kooks headers with Kooks x pipe in order to fit properly along with the necessary tune and CAI. $3200 installed.
ARH mid tubes only give up about 10 HP over long tubes and bolt right up to the factory X pipe
here is just one post about them being put on a car without a tune from Vengence Racing , one of the most respected shops
https://www.corvetteforum.com/forums...ideo-dyno.html
Dave
Dave
Former Vendor
If you run ARH or Kooks you'll have to use their x-pipe as well for the proper connection, and can sell your Corsa x-pipe relatively easily. We've done a few Corsa header installs as well to mate to their x-pipe and no real complaints there either. That pricing is about right if you factor in parts, labor, GM gaskets, heat sleeves on the wires, and the oil/filter you'll have to do on a dry sump car as well as tuning. Do NOT run the short/mid length units unless you just want to change something on the car. The longtubes will enhance both performance and sound much more than the other options and are the only way to spend money on that section of the exhaust.
I am an ARH and Kooks dealer if you're interested in a system for the car that we can help with as well.
Received 1,762 Likes
ttt
^^^ I agree with you David but to the op here get are go with the ARH much better in my book. Robert
Throttle Response
Do you guys that installed full length headers on your C7 feel like the throttle response was lessened? Do you think you lost any low end torque?
Well in 3 days it burn a hole into my A/C line called the guy I got them from at KOOKS after 2 days of talking he told me he was sorry but he wouldn't do nothing about it. I pulled them sold them got the ARH 2 inch headers they went on much better & wasn't as close to the A/C line cost me 125.00 to fix the A/C line plus what I lost on the sell of the headers. Robert
C7 of Year Finalist (performance mods) 2019
Party pooper alert.
This isn't the '70s anymore. $3+K to gain maybe 10 top-end Hp on a 460HP engine? Is it really worth it? I can't use 50% of the hp on the street, and even on the racetrack, if I disable the TC, the car is sideways half the time. Lots of money to just add noise, IMHO, but its your money.
Zodiak77 (01-25-2020)
Party pooper alert.
The following 2 users liked this post by lakemg:
c6txvette (01-24-2020),
C7 GrandSport (08-19-2022)
The lines from the engine to the reservoir need to be removed to install the passenger side. If your oil isn't due for a change in a while, you can do what I did and capture it in a clean container and reuse it.
Better fitment in my book I know this was from my c5 set up. But bought a new set of KOOKS from them on a set of 2 inch headers. I made it a point to ask if these were the new version & not the old version. I was told these are the NEW that will not burn out r a hole into the A/C line. Well they did I even called them back & told them it was about what ever close to the A/C sent them a pic of it with the box part #.
Did the sound change much going from Kooks to ARH?
Do some research on the ARH mIdlengths vs longtubes. They do not give up much power, maybe 10HP at peak. The consensus is 15rwhp for mids and 25rwhp for longs. However, only the ARH mids will bolt up to your Corsa X pipe. Longtubes will require changing your X Xpipe too. But it should bolt up to your NPP exhaust, both factory or aftermarket.
BearZ06 (02-19-2020)
Not really if any at all the kooks headers was made good from looking at them. It was just the problem I had and me going over it with the guy & buying them new from them & then not standing behind what I was told.. But the ARH was a better fit on the car getting them things in the car with the motor still being in the car. On the KOOKS I had to remove even the steering from the firewall to get them in the car. The ARH I didnt but had to remove the starter for both. Robert
lakemg (01-13-2019)
Former Vendor
https://vengeanceracing.net/2014-tru...-set-of-8.html
For Jet-Hot, we use them quite often and really comes as more of a preference or based on usage of the car for the customer. The C7's aren't quite as bad about transferring the heat into the tunnel area as the older C5/C6 cars were, but any time that we start to see more aggressive exhaust temps (supercharged cars, road racers, autocrossers, etc.) we start to recommend coating the headers. It definitely won't hurt either way and we have had much better luck with Jet-Hot than any other coating companies we've been able to use.
